Old 04-11-2023, 06:59 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
What does this wire attach to ?
We have the wiring figured out except for the big red wire in the picture over engine. It has 2 female connectors on the end and look to bed a little thicker than most other wires. We cant figure where it is on the wiring diagram either. Anyone know what it connects to ? I also posted this in the Electrical Thread. Just realized my truck has factory A/C and do not see anything on wiring Schematic showing the compressor wiring.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-11-2023, 07:35 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: What does this wire attach to ?
It looks purple to me. That would be to the starter solenoid "S" terminal, except that has a round end for the stud on the solenoid. Looking at the 12R wiring, I'm not seeing a place except possibly at the voltage regulator.
~Steven
Simi Valley, CA
Old 04-11-2023, 07:54 PM   #3
dmjlambert
dmjlambert's Avatar
Trace the wire back to the firewall block where it goes in the cab. What position is it in? Or does it go somewhere else? Why do you say it has 2 female connectors on the end? The picture does not seem to show that.
Old 04-11-2023, 08:40 PM   #4
Already Gone
Thanks for the reply. It does look a little purple I guess but its not the starter wire as its connected already.
Old 04-11-2023, 08:41 PM   #5
Already Gone
Your right its a single connector..
Old 04-11-2023, 09:13 PM   #6
RustyPile
RustyPile's Avatar
I see your truck has factory air conditioning. In the factory AC wiring, the wire carrying power from the blower relay to the blower is purple..
Vettevet posted a wiring diagram in an old 2016 thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=705082
RustyPile is offline   Reply With Quote
Old 04-11-2023, 10:06 PM   #7
60case
I would think it goes to the idle solenoid
60case is offline   Reply With Quote
Old 04-11-2023, 11:19 PM   #8
davischevy
davischevy's Avatar
Fast idle solenoid for AC. See it just to the right of the thermostat? I can get a better pic if you need it.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 04-11-2023, 11:23 PM   #9
davischevy
davischevy's Avatar
Another.
other Larry
Old 04-12-2023, 12:57 AM   #10
Already Gone
Originally Posted by davischevy View Post
Another.
Thanks Larry and pic is from original engine and looks like that wire came down the drivers side of the block on mine.
Old 04-12-2023, 10:24 AM   #11
jumpsoffrock
I'm no expert, but I've been to many trips to the junkyard and I've never noticed a car with that solenoid using wire of greater gauge than maybe 16, tops.
jumpsoffrock is offline   Reply With Quote
Old 04-12-2023, 11:05 AM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'm used to a green(?) wire, about 16 Ga. Things get modified over the years. That fat wire looks like if would be pretty tight in the clip on the valve cover.
~Steven
Simi Valley, CA
Old 04-12-2023, 02:07 PM   #13
RustyPile
RustyPile's Avatar
regardless of color or terminal type, do not just blindly connect this wire to some random accessory.. Looking at photographs to determine where it might connect is pure guess work no matter who is doing the guessing. Trace the wire back to its point of origin and refer to a wiring diagram to determine EXACTLY where it goes..
Old 04-12-2023, 02:29 PM   #14
davischevy
davischevy's Avatar
I think you are right. I will review my pre resto pictures.
other Larry
Old 04-12-2023, 02:51 PM   #15
Steeveedee
Who Changed This?
Steeveedee's Avatar
This, for sure!
~Steven
Simi Valley, CA
Old 04-13-2023, 02:46 PM   #16
custom1970
Member
custom1970's Avatar
If it's RED I a have a similar wire that goes to my tach. Old pics, but the location and size look similar.
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 04-13-2023, 08:14 PM   #17
truckster
truckster's Avatar
Where's the fun in that? And how are you supposed to test your fire extinguisher?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-13-2023, 08:17 PM   #18
jaros44sr
jaros44sr's Avatar
Funny guyROTFLMAF per se
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-13-2023, 11:54 PM   #19
Already Gone
Thanks everyone but the wire is in itsrightocaion now as are all the others and fond out a couple were redundant. Just s just about donw witha few small details to button up. Snow and Winter road grudge are almost so can drive the truck when done.
