Old 03-31-2023, 11:56 AM   #1
425HP409
425hp409
425HP409's Avatar
6 Lug Wheel Question
Will late model 6 lug wheels fit on a 70 with original 6 lugs?
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Oldsmobile 442, all original
425HP409 is offline   Reply With Quote
Old 03-31-2023, 01:39 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: 6 Lug Wheel Question
Late model 6 lug has a bore of around 80mm, I know the rear hub on my 69 GMC was bigger, didn't even try the front. 16x6.5 wheels, 14mm wheel studs. Would have to get 1/2 or 9/16 wheel studs. Those wheels are what I was trying to fit.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 03-31-2023, 05:13 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
A friend gave me 4 aftermarket aluminum 8x16 rims off his '99 Suburban. The 6-lug at 5.5'' spacing was the same, but the setback was too shallow. The wheel bore accepted the Dana 44 hubs on my 4x4 K/1500 GMC Jimmy [K/5 type], but I had to buy 1.25'' wheel spacers to mount the new-to-me rims with 235/75/R16 tires.
A weird noise on the freeway, got me to pull those wheels and spacers -- thinking something internal was coming loose. Even though Discount Tire had used 3 different sized lugnuts to mount the tires -- that wasn't the real problem.
My front prop shaft was disintegrating. I had given them 25 all new gold anodized lugnuts, but they were too fat for the recessed holes in the fancy aluminum rims.
So now my fancy lugnuts are holding my old 33x12.50x15 meat tires on at a proper 90 foot pounds.
Old 04-12-2023, 10:01 PM   #4
425HP409
425hp409
425HP409's Avatar
ttt
Charles
Old 04-13-2023, 12:38 AM   #5
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
So now my fancy lugnuts are holding my old 33x12.50x15 meat tires on at a proper 90 inch pounds.
I think you mean 90 foot pounds.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 04-14-2023, 03:20 PM   #6
425HP409
425hp409
425HP409's Avatar
With respect to the previous posters, your answers are not on topic. a 70 C10 2wd is what I need wheels for.
Charles
Old 04-14-2023, 03:41 PM   #7
michael bustamante
michael bustamante's Avatar
so any wheels designed for gm larger 6 lug after 1999 will not seat on our hubs, you have to use a spacer..
1967custom
michael bustamante is offline   Reply With Quote
Old 04-19-2023, 06:55 PM   #8
425HP409
425hp409
425HP409's Avatar
So then I would have to install longer lug studs?
Charles
