Old 04-17-2023, 09:30 PM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by pjmoreland View Post
If my memory serves me, there's a nice orange stepside cab in the Tucson area that already has a pair of bucket seats in it!!
Actually, that's a '69 Ford Thunderbird seat with bench seat, bucket backs and a fold-down center cushion in the Orange '68 C/10 Stepside. Also it was once electrically-adjustable. Not much swing with the Tank in the cab, though. I don't have the 6-axis switch connected bc it draws over 30 Amps. [Once I ran some handy 12/14 gauge brown wire to feed it. I forgot that was Fuseable Link line. After I adjusted the seat, the switch stuck in ON, and my ''brown wire'' cooked off. I grabbed it with my bare hand to yank it off, and branded a line across my left palm.]
The Jimmy needs new seats badly. The ones the PO put in are out of a Firebird/Camaro car from thre mid-80s. The foam was molded around the springs, and it's shot. Sharp pokey things pop up into one's posterior. And at the rear, the brackets are lag-bolted into 4''x 4'' blocks of wood. A head on collision will be fatal.
It's the '67 Suburban, I'm thinking of Buddy Buckets in. Shotgun rider could ''lay aft'' and check on the load, [or retrieve a cold one] from the back while underway.
Current stock '67 vintage bench seat is OK. Would be great after reupholstering.
Just kidding. Keep your seats. You found them. You build them. Only fair.
