Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-19-2023, 09:04 PM   #1
caseyjones
WTB: 60-62 half ton spindles and brakes
Throwing this out here - if anyone has done a disc brake swap on a 1960-62 c10 and needs to unload the original setup I have a buddy that could use it. He's got a 62 C20 that im helping him convert to half-ton running gear and keeping the drum brakes isn't a problem. Thanks!
caseyjones is offline   Reply With Quote
Old 04-22-2023, 09:34 PM   #2
62c30
Re: WTB: half-ton front suspension
I've got one but I imagine I'm a little too far
62c30 is offline   Reply With Quote
Old 04-22-2023, 11:36 PM   #3
franken
My small understanding is square front suspensions bolt up with a few new holes drilled.
Old 04-22-2023, 11:39 PM   #4
62c30
They will bolt in with a little work. I did that on a 60 frame and gave away the old front end. Now I'll be doing a 61 so I'll have an extra front suspension. I hate crushing parts someone can use.
Old 04-23-2023, 01:44 AM   #5
caseyjones
Angry Re: WTB: half-ton front suspension
If you’re willing to ship just the spindles and backing plates that would be a start…i hear that hubs from a 63 and up will fit the spindle and have roller bearings so I’d want to update to those anyway…
Old 04-23-2023, 02:15 AM   #6
FamilyTruckster65
Not me. Found on Craigs list
https://seattle.craigslist.org/tac/p...612888232.html
FamilyTruckster65 is offline   Reply With Quote
Old 04-23-2023, 11:00 AM   #7
62c30
I would be willing to ship, I haven't pulled the front end yet.
Old 08-31-2023, 11:22 PM   #8
caseyjones
Bumping this back up…
Old 09-01-2023, 08:03 AM   #9
tchevs
If you were in California.
tchevs is offline   Reply With Quote
Old 09-07-2023, 12:17 AM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: WTB: 60-62 half-ton front suspension
I have the front cross member, a arms, center link, spindles, actually the whole front suspension for a 73-89 gm 1/2 ton. It has 5 lug rotors.
I was going to use it to convert my 65 that is on a 62 frame to disc brakes.
I have had some health issues come up and I actually have my 65 for sale. So my upgrade isn't going to get done.
You can have it all with the sway bar for $100.
I'm in Oregon City, Oregon.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-07-2023, 11:33 AM   #11
caseyjones
I’m sorry to hear that you are dealing with health issues. That sounds like a smokin’ deal, but for many reasons I’m looking for the half-ton 60-62 spindles and drum brakes instead of a full crossmember swap. We are also looking for a set of 6-lug stock steel wheels.
Thanks for the offer!
Old 09-08-2023, 12:30 AM   #12
LostMy65
LostMy65's Avatar
Re: WTB: 60-62 half ton spindles and brakes
Thanks for the kind words.
If you're looking for 60-62, does your buddy's 3/4 ton have torsion bars for the front suspension and you're wanting to go to the 1/2 ton 60-62 torsion bar front suspension?
I'm not as familiar with the 60-62 3/4 ton, but is it an x-frame?
Old 09-08-2023, 12:52 AM   #13
caseyjones
Correct, it’s the original x-frame with the torsion bar set up. Ball joints are the same part number for 3/4 and 1/2 ton trucks, but I think the outer tie rod ends are different…should be a straightforward swap though. He’s got a 6-lug rear that he’s planning to put in it so we need to swap the front to get a matching bolt pattern.
Old 09-08-2023, 02:43 PM   #14
1960chevypanel
I have 60-62 1/2 ton spindles and hubs if you're still looking. By the way roller bearing hubs will NOT seat properly on the early spindles.
1960chevypanel is online now   Reply With Quote
Old 09-08-2023, 05:28 PM   #15
caseyjones
That’s good to know about the roller bearing hubs. I’ll send you a PM…
