08-08-2004, 01:28 AM | #1 |
2pc. driveshaft needed
I'm in need of a 2pc. driveshaft for a SWB TH350 short tail, if they even make one. Have problems with the the 1pc knocking against the crossmember.
08-08-2004, 06:24 AM | #2 |
If you were closer i could fix you up, i have 9 of them and the carrier bearing mounts but shipping to AZ would be 30-35.00.
Rest in Peace Ed. Thanks for all the good times. |
08-08-2004, 12:21 PM | #3 |
"Trucks with Class"
I just pulled one out of a SWB. It is inside, clean & protected. PM for details.
08-08-2004, 12:30 PM | #4 |
Chevy Freak
Driveshaft
$50 shipped to you. Just pulled out of a 72 shortbed. Brian
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
08-08-2004, 11:59 PM | #5 |
"Trucks with Class"
I yield to Burnsman...I can't pull, store, box, deliver and ship a driveshaft for $50...that's a "freebie"...go for it!
08-09-2004, 09:44 AM | #6 |
Senior Moment
Why is it knocking on the crossmember????? When you put in the 1 piece did you remove the carrier bearing bracket?? I have a 1 piece and have NO problems
I'd check out WHY 1st. a 1 piece is much better
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
08-10-2004, 01:35 AM | #7 |
Well I took out the lower bearing bracket when I restored the truck and just threw in a 1pc, now its lowered alittle and it's knocking pretty bad when I'm hauling my quad in the back.
08-10-2004, 09:50 AM | #8 |
Take a torch,plasma cutter or sawzall and trim the crossmember a little bit at a time until it clears.
08-10-2004, 09:53 AM | #9 |
Senior Moment
Where is it hitting?? When you haul your quad the truck goes down, are you sure your drive shaft isn’t to long and its bumping up against the tail housing??, Just a thought. My truck is lowered 3" front 4" rear and I have no problem with a load.
You also say you just threw in a 1 piece, where did it come from or did you have it made.
08-12-2004, 01:36 AM | #10 |
Yes, I'm sure its knocking against the Crossmember, because I checked while I had a load in the back, and the shaft is about an inch from hitting the cross member. the shaft came from a wagon which fitted just right.
