View Poll Results: If you had the option, which of these grills would you use? | |||
Original 66 painted grill | 1 | 20.00% | |
64-66 C60 painted grill | 2 | 40.00% | |
an original aluminum grill that needs to be restored | 2 | 40.00% | |
the repo aluminum grill that is now available | 0 | 0% | |
Voters: 5. You may not vote on this poll |
04-27-2023, 12:43 PM | #1 | |
Re: pdx-sanity66
I've slowed down a bit on Sanity right now. It's going in for paint in June so there's not a lot of things left to do until then. I have worked on the bed sides that had 4 or 5 quarter to half dollar sized but very shallow dents in the front part of the bedside that I believe I did while aligning the bed, oops. I have one of the dent pullers that uses glue on tabs that hook up to a slide hammer. This worked great and I was able to remove the dents. I'm ready to spray some epoxy on the affected area and also spray the interior door panels that are also ready.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
05-23-2023, 03:24 PM | #2 |
Re: pdx-sanity66
I'll be leaving for Portland in the middle of June with a stop off in Utah to visit my brother and sister on the way back. While we're gone, Sanity is going in for final block sannding and PAINT. I will be getting progress pictues while I'm gone so I'll try to post some. Stay tuned.
