![]() Join Date: Feb 2016
Re: 1971 Suburban 4x4 build "The Big Ugly"
Bending brake lines isn't too tough. Here are some things I've learned over the years. It just takes some patience and pre-planning of your moves.
Get a 25 foot roll of 3/16" nickel/copper brake tubing. If you're unfamiliar with Nicopp line the interweb has lots of information. You don't want nickel/steel tubing. Although some trucks used 3/16 for the front lines and then 1/4" for the run to the rear brake hose and then 3/16 on the axle so you may need only 15' of 3/16" and then 15' of 1/4". Get a quality tubing bender. I like Imperial benders. They will do 180 degree bends. Get a 8 foot long piece of #6 solid uninsulated copper wire. #6 is slightly smaller than 3/16" tubing. Then you can make practice pieces with the copper wire before trying it on the tubing. I like to start on smaller easy to access lines like the ones on the rear axle to start. Then once I've got my MOJO going then I move on to the longer, harder to access lines. Some of the frustration with bending new lines come when you're replacing ones on an assembled vehicle. GM designed the lines to be installed on unassembled vehicles. So sometimes you have no choice but to put an extra coupling in the line. I also like to take pictures of all the fittings before I start so I can make a shopping list of those if I'm going with all new fittings. GM has a habit of using different sizes. I believe they did it to keep the folks on the assembly line from assembling things incorrectly. I hope this helps. Looking forward to more updates on your Burban!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
