Old 04-25-2023, 07:09 PM   #1
bennylava
bennylava's Avatar
Press and hold fuel tank switch?
I'm hoping someone here can explain the difference between the two types of fuel tank switch. I bought a GM brand replacement switch, because the old one died. But it was so difficult to plug in, that I thought maybe I bought the wrong one.
Since they're so cheap, I went ahead and got a Dorman brand one and it fit great and works great.
I noticed that the GM is the press and hold style switch, while the Dorman has no such function. You just flip it one way or the other. What's the difference here? Did the seller perhaps ship me the wrong GM brand switch? Maybe my 87 truck isn't supposed to have that kind of switch, and that explains why it didn't fit the socket.
It looked like the pins lined up, but I couldn't get them to go in. Wasn't going to try and force it and break something. Thanks!
bennylava is offline   Reply With Quote
Old 04-25-2023, 10:03 PM   #2
Dleslie212
Re: Press and hold fuel tank switch?
From what I understand, it's based on which tank selector valve you're using. The old style, three port valve only needs voltage when one tank is selected. When no voltage is present, it automatically reverts to the default tank, which I think is passenger side.
The newer six poet valves need momentary voltage to switch which tank it's drawing from, but then they stay on that tank until switched again.
Dleslie212 is offline   Reply With Quote
Old 04-25-2023, 10:27 PM   #3
Just call me Sean
Just call me Sean's Avatar
'87 up would have electric fuel pumps.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 04-26-2023, 12:42 AM   #4
Dead Parrot
Pretty much what I understand as well, except there were some 6 port solenoid valves that use the simple flip switch. Replacement 3 port valves are still available while the 6 port are unobtainium unless you are lucky in a salvage yard or resale site. Because of that, there are several swap threads on here that address changing from the solenoid type to the motorized type.
The newer motorized 6 port valves need the press and hold switch to allow the motor to swap tanks. Pretty sure that by 87, the motorized valves were the standard but who knows what a PO might have done to fix a tank valve issue.
Dead Parrot is offline   Reply With Quote
Old 04-27-2023, 11:41 PM   #5
bennylava
bennylava's Avatar
So they probably sent me the wrong switch, and that's why it wouldn't fit. The simple flip-switch works fine to switch between tanks. When everything is functioning properly, that is. I've replaced the switch, and the selector valve. Both of them got the passenger side tank functioning again, for a while.
Now I guess I have to go after the fuel pump.
Old 04-28-2023, 11:19 AM   #6
kwmech
Hatzie has a good write up on these systems along with full diagrams. Depending on the years of your truck, some parts may be obsolete and needing conversion
Old 04-28-2023, 04:39 PM   #7
hatzie
Moderator
hatzie's Avatar
1981-1986 CK series DEPRESS FULLY switches are momentary action polarity reversing switches with a center off position. You press to LH or RH and hold til the motor on the Pollack motorized valve moves the shuttle to the selected tank.
The 1987-1991 RV series dual tank switches are ON-ON switches since the TBI fuel pumps get power from the dual tank system. I use these switches on all trucks from 1981-1991. The Pollack motorized valve has always had switches inside to shut off the motor once the valve has moved to the stops.
One of the four male terminals on the switches has a lump to prevent being plugged in backwards. The TBI switches have the lump on a different terminal from the earlier momentary switches.
You can use the 87-91 switch on the 81-86 systems by filing a notch to accommodate the new lump location.
Here's the Theory of operation thread covering all the dual tank systems used on the 1973-1991 squarebody trucks.
https://67-72chevytrucks.com/vboard/...d.php?t=754061
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-28-2023, 05:34 PM   #8
bennylava
bennylava's Avatar
So to clarify, depress fully is NOT "press and hold"? My 87 uses the simple flip switch, which functions like a light switch in your house.
Side note, I'll definitely make use of that fuel pump test terminal shown in the link. Never knew that was there and will be quite useful.
