Old 04-28-2023, 07:26 PM   #1
28TudorAZ
28TudorAZ's Avatar
1969 International Scout 800 LS Swap
Picked this up a few years ago and it has now officially moved to my garage as a project last week. First things I am doing are putting the springs back under the axles and prepping the LS engine.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
28TudorAZ is offline   Reply With Quote
Old 04-28-2023, 10:45 PM   #2
Willowrun
Willowrun's Avatar
Re: 1969 International Scout 800 LS Swap
As a fellow IH owner I'll follow. Still undecided on the LS swap though as I like the heavyweight IH engines for some reason. Looks like a clean 800 to start with.
Old 04-29-2023, 01:28 AM   #3
28TudorAZ
28TudorAZ's Avatar
Thanks. I want reliability so decided on this route. Here is a picture of it cleaned up and the engine ready to go in. Working on the suspension right now and gas tank next.
Old 04-29-2023, 07:07 AM   #4
mongocanfly
mongocanfly's Avatar
Very nice..!!..for a Scout, that one looks very solid
The LS will make it a rocket ship
What's the plan for a trans and transfer case?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-30-2023, 12:10 AM   #5
28TudorAZ
28TudorAZ's Avatar
Definitely should have some power. I put a BTR Stage 2 cam and new valve springs since I was resealing everything. 4L60E with NP241C transfer case.
Old 04-30-2023, 12:40 AM   #6
mongocanfly
Cool..!!!!...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-30-2023, 09:36 AM   #7
Willowrun
Willowrun's Avatar
Yes, very nice!
Old 05-06-2023, 05:41 PM   #8
daveshilling
daveshilling's Avatar
Come clean up MY LS please! Looking good
daveshilling is offline   Reply With Quote
Old 05-31-2023, 11:50 AM   #9
28TudorAZ
28TudorAZ's Avatar
Originally Posted by Willowrun View Post
Yes, very nice!
Thanks!!!
Thanks!!!
Made some progress on the gas door and fuel tank. I need to find the correct hoses. I having been rolling the dice with Amazon with no luck since they dont have measurements listed. I did get one that had the right sizes hoses but not long enough. I have my old engine sold so I need to get it out this weekend.
Old 05-31-2023, 02:31 PM   #10
mongocanfly
Might look here.i think this is where I've found one before.
https://www.fillernecksupply.com/fue...hose-straight/
I found a place a couple yrs ago that has all kinds of fuel hoses when I was at work and have it saved on my work computer...I had to have a hose I couldnt find anywhere for my C30 when I built the bed for it..they had what I needed.. I "think" the site above is it... I'll verify tonite when I'm at work..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-04-2023, 02:25 AM   #11
28TudorAZ
28TudorAZ's Avatar
Thanks I am going to check that out.
I sold the old engine today and it got pulled. Now the fun begins.
Old 07-22-2023, 01:29 AM   #12
28TudorAZ
28TudorAZ's Avatar
Got the radiator mounted. Found an LS Swap Radiator from a 68 impala and had the move the bracket to the front. Also made an adapter plate and used an early 70's chevy truck power booster. Next up is the Nissan Power steering box and the steering column. Then I can start thinking about mounting the engine.
Old 08-04-2023, 11:24 PM   #13
sduckworth13
sduckworth13's Avatar
Keep posting ��. Truck looks great to start and your welding skills are top notch.
Scott
sduckworth13 is online now   Reply With Quote
Old 08-06-2023, 04:54 PM   #14
LS short box
Not a Scout LS swap but my 98 Wrangler LS6/4L60E I used a Rubicon 241R TC due to its wider TC chain and 4:1 low range. If you don't have it I would add a wide chain kit and SYE to the 241. Also add a CV drive shaft. Maybe also add 1350 u-joints to the drive shaft and axle yoke.
Man I like spending other peoples money. LOL.
Good luck with your project.
Old 08-07-2023, 07:57 AM   #15
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Subbed to watch, nice looking scout
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-21-2023, 08:11 PM   #16
28TudorAZ
28TudorAZ's Avatar
Do you think it needs the wider chain with the transfer case being from a full size Chevy suburban? It has a CV driveshaft already that I was going to see if I can reuse. This was originally a V8 scout scout so I am thinking I can reuse most parts but any recommendations are appreciated as this is my first 4x4 build. Too be honest the front end is a mess and really needs to be thought out. I need to figure out the power steering. Scout II steering boxes are not really available.
Old 08-21-2023, 08:11 PM   #17
28TudorAZ
28TudorAZ's Avatar
Thanks!!!
Thanks!!!
Old 09-10-2023, 01:20 AM   #18
28TudorAZ
28TudorAZ's Avatar
Tacked in the motor mounts today. Next up is building the transmission mount then taking it all back out to finish welding up and painting.
Old 09-12-2023, 09:28 PM   #19
LS short box
Good question on the 241. That I don't know.
In the back of my TJ I'm running a 8.8 out of a mid 90's explorer. 4.10 gears with posi. Stock TJ front axle with 4:10 gears. I haven't broke it but my TJ is a mall crawler.
Tons of used TJ/JK parts out there for swapping into what ever.
I'm wondering if a TJ power steering box might be a some what bolt on?
Old 09-13-2023, 03:00 PM   #20
28TudorAZ
28TudorAZ's Avatar
I figured out the steering box issue. I ordered a right hand drive Newer JK steering box aka Postal Jeep Wrangler JK. When I pull the engine I am going to build the mount for that.
Old 09-23-2023, 03:20 AM   #21
28TudorAZ
28TudorAZ's Avatar
Getting closer. Have the transmission mount ready to tack together but need to put the transfer case on to make sure the driveshaft will clear it.
Old 05-28-2024, 12:21 AM   #22
28TudorAZ
28TudorAZ's Avatar
New ride height. New springs. Switched to spring under with a dana 44.
Old 05-30-2024, 12:33 AM   #23
mongocanfly
lookin good !!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-30-2024, 08:52 AM   #24
Ol Blue K20
I like it!
Dale
Old 10-27-2024, 10:41 PM   #25
28TudorAZ
28TudorAZ's Avatar
Mounts are done and engine is in to finally in. Now I should be putting things in for the last time.
