I looking for a radiator for my 67 GMC. I read some old post and some referred to the CU396 radiator. But they seem to be out of stock everywhere so I called spectra to see what the deal was and the guy told me they were discontinued..
So now the options to get mine record ($500) or buy a aluminum one. I also have read that the aluminum ones don't fit in the stock mounts properly.. What is others using for replacements? |
Re: What Radiator?
I went down the re-core route on my Burban. I had to wait an extra 2 weeks to get a quality 4 row core from Canada but it's been flawless since installed some 40k miles ago.
I tried a Cold Case but, sent it back as it uses 3 row side tanks and our trucks only came with 2 or 4 row tanks. So you have to fabricate new mounts or just let it flop around in the 4 row mounts. It really annoyed me that they advertise it as direct fit when in reality it isn't. For more information on that little adventure scroll to post 333 in the link. http://67-72chevytrucks.com/vboard/s...698377&page=14
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: What Radiator?
Must be old news. I bought a Cold Case 2-row aluminum radiator about 5 years ago, and it dropped right into my old 4-row Brass radiator's mounts, top and bottom.
Re: What Radiator?
I bought a Champion 4 core for my 71. It's not been a year and I just dropped it off at a local shop for a leak. It will be my last one. It fit ok though.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1969 C10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
Re: What Radiator?
x2 post 3 put my cold case in 2-3 years ago and it fit nicely. not perfect but good enough. chuck
Re: What Radiator?
Just just upgraded to a 3 Core from the stock 250ci 2 core radiator. I found an original 3 core in the classifieds and had it pressure tested and cleaned out by a local rad shop, Works great! Might be another option you could check out.
PS, even the radiator shop owner said they don't make them like they used to when I picked it up! He loved seeing the old 3 core
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
Re: What Radiator?
Unfortunately all the "radiator shops" have left my area, most likely all of CA with its rigid "you can't do that" environmental laws.
If I needed a new radiator, I would get a Cold Case. Modern Aluminum and 2 LARGE (read better than more little) rows. You can paint it black if you want to look "original".... |
#8 | |
Re: What Radiator?
Re: What Radiator?
I've bought several of the Summit reproduction radiators with no issues
#10 | |
Re: What Radiator?
https://www.summitracing.com/parts/sum-382006 -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#11 | |
Re: What Radiator?
![]() ![]() Join Date: Feb 2009
Re: What Radiator?
1k gets a us radiator . They're built very well and fit perfectly. I didn't much care for the summit replacement. Cheap fittings and has the vertical structural straps.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: What Radiator?
Re: What Radiator?
$ 1000 .
I had several cheap import radiators in the past . Two Champions and one I forgot the brand all failed in a couple of years. Went with Dewitts HP and not a problem in the past 5 years . Yes they are twice the price but having to repair or replace every few years isnt appealing to me . I bought a Cold Case for my 72 at the Syracuse nationals a few years ago because it was a show special as the shroud had a minor dent in it (Not even installed) assume it was a return unit . I have yet to install ot as the original is still working well
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#15 |
Re: What Radiator?
"If" I needed a radiator, I would get this one. I have had one in my 67 camaro for 2 years now, no issues. Fit and finish was a direct drop in for that car. I assume the same for the C10 model
https://www.coldcaseradiators.com/pr...case-radiators |
#16 |
Re: What Radiator?
I replaced a slightly leaky 4 row original, with a Champion 3 row. Fit was close, and it still needed the longer 4 row radiator mounts. Both radiators had equal run times in severe heat on my daily driver, in traffic. (up to 110 last summer)
Both radiators cooled exactly the same. Running a fan w/clutch and shroud. |
#17 | |
Re: What Radiator?
#18 |
68 C10 Longbed
Re: What Radiator?
Not about a Cold Case, but I had the original (2) core radiator and brought it to be recored, I was able to keep the original Harrison sides and tag and he upgraded me to a 3 core. Cost me $450 and have been using it on a new Blueprint crate engine and it runs 180 all day long with new issues.
#19 |
Re: What Radiator?
Got mine from these folks. https://speedcooling.com
Had one of the Ebay specials and the one from Speed Cooling is much heavier gauge and fit perfect in the original mounts. |
#20 |
![]() Join Date: Jul 2021
Re: What Radiator?
My 72 C20 has a custom radiator made by Wizard Cooling. Fits and works great. No problem in the Texas Summer with AC on full. My big block 511 runs around 180 degrees with the AC on and outside temp over 100 degrees.
#21 |
Re: What Radiator?
Here is a few more pics of the Wizard Cooling unit.
#22 |
![]() Join Date: Feb 2022
Re: What Radiator?
Be cautious when inspecting the fit of the aluminum radiators into the 4 core mounts. The rubber liner on the mounts will compress enough the it can allow contact of radiator with the edge of the mount. I found this on my 4 row Champion. The hard edge of the mount will saw a hole over time. Best test, though not 100% perfect, is do a continuity test on the radiator to the radiator support before any lines are connected. If you have an open circuit you have good indication there is no metal to metal contact that could wear a hole over time.
#23 |
Re: What Radiator?
I bought an eBay special back in 2018. Has been working great cooling the big block ever since.
https://www.ebay.com/itm/161604421849 |
#24 | |
Re: What Radiator?
| Bookmarks |
| Tags |
| radiator |
