Old 05-02-2023, 12:03 PM   #1
Dodge68charger
Originally Posted by pjmoreland View Post
Here are some measurements of the original screw style. It's a "B" type tapping sheet metal screw with a hex drive and a built-in washer.
Thread Diameter = .187" (#10)
Thread Pitch = 16 tpi
Thread Length = 5/16"
Hex Drive = 1/4"
You'll probably be able to find something like this at a hardware store:
https://www.mcmaster.com/92525A550/
Thank You! Exactly What I Needed. Appreciate It
Dodge68charger is offline   Reply With Quote
Old 05-02-2023, 12:38 PM   #2
Don D
Junior Member
#10 screw 5/16” long. Most #10 screws at the hardware store will have a 5/16” hex head on them, they will work as there is enough room for a socket or wrench. If you can’t get on short enough, take something like a cut off wheel on a dremel tool & cut it to length. 1/4” in length will work also, I would not go any longer than 5/16” as it would bottom out on the shift tube inside the column.
Don D is offline   Reply With Quote
Old 05-02-2023, 02:54 PM   #3
Dodge68charger
Thank You
