Old 05-03-2023, 12:19 PM   #3751
OregonNed
OregonNed's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by '68OrangeSunshine View Post
Thanks, Grumpy.
Yes, Amazon for me too. I've ordered many for all of the hoses, including the main upper and lower radiator. They are actually pretty reasonable. I made sure to measure the smaller hoses to get the right millimeter range - the first ones were too small. Most of them I also polished up a bit on the buffing wheel
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 05-04-2023, 04:34 AM   #3752
kelz702
I didn't do all this today. It took me a few weeks but I finally got these wheels on the truck. I bought an old set of f@>d wheels and had them powdercoated(cosmic white metallic). I took the truck to the wheel shop and had some firestones mounted and ballenced. Brought the truck home and slapped these hubcaps on. I'm calling it good for a little while
kelz702 is offline   Reply With Quote
Old 05-04-2023, 05:32 AM   #3753
kelz702
Here's some more pictures:
Old 05-04-2023, 09:28 AM   #3754
68bowtie
68bowtie's Avatar
Looks great
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 05-04-2023, 10:21 AM   #3755
Micmac
Micmac's Avatar
Gotta Love the orange and white! Looks awesome
Micmac is offline   Reply With Quote
Old 05-04-2023, 10:22 AM   #3756
Micmac
Micmac's Avatar
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Old 05-04-2023, 10:50 AM   #3757
Chevys4life
Rims and tires always make a big difference.
Chevys4life is offline   Reply With Quote
Old 05-04-2023, 12:37 PM   #3758
LNP
Originally Posted by OregonNed View Post
One of my Heater hoses had an annoying drip, so I upgraded both with new clamps - silicone style instead of the ones I had.
What do you think of the silicone hoses? Did you switch the radiator hoses as well or just the heater hoses?
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 05-04-2023, 12:39 PM   #3759
LNP
Originally Posted by TxGary View Post
Installed LED bulbs in dash cluster, now I can see the guages at night. Also installed a 15" steering wheel.
Looks great. I too swaitch mine to led's and I have that steering wheel too. I switched my park, backup, and turn/brake lights to led's. They are real bright
Harley
Old 05-04-2023, 01:33 PM   #3760
OregonNed
OregonNed's Avatar
I'm glad you called me on this, because in my research I assumed it had the silicone component - actually, EDPM rubber. As opposed to other hoses I had, it has a rubbery feel, (not smooth like the Goodyear Hose) - seems to be much better quality and sealing better.
Old 05-04-2023, 05:41 PM   #3761
LNP
Cool thanks for the info I appreciate it
Harley
Old 05-04-2023, 08:49 PM   #3762
zicc1835
zicc1835's Avatar
I got me E Brake pedal ready to install and decided to rebuild the kick panel vent door drilled out the rivets replaced with stainless screws and nylocs I powder coated it new gasket and installed it real nice tight fit easier than having the E-pedal in the way ....I guess
zicc1835 is offline   Reply With Quote
Old 05-04-2023, 10:07 PM   #3763
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ Nice work! Back in my prime...
~Steven
Simi Valley, CA
Old 05-05-2023, 01:16 PM   #3764
72c20customcamper
72c20customcamper's Avatar
Tried the Eastwood brake line flairing tool for the first time to make a gas line for the 68 . Worked very well just need to get a holder clamp for the line so it doesn’t vibrate to much . I tried to replicate the oem as best I could but since I added an in-line it’s not factory correct
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-05-2023, 01:39 PM   #3765
HalfBrit
Nice work!
+1 for the Eastwood flaring kit. As a certified tool junkie, I don't mind paying extra for something that gives quality results and makes the job easier.
HalfBrit is offline   Reply With Quote
Old 05-05-2023, 03:01 PM   #3766
D.B
D.B's Avatar
X2 for the Eastwood Flaring tool. I use mine making up brake and fuel line. Flares come out looking machine made.
D.B is offline   Reply With Quote
Old 05-05-2023, 05:41 PM   #3767
72c20customcamper
I bought it last year at the Carlisle truck show . Blew a line from the master to the block on the crossmember . Couldn’t get a line with the same fittings . So I bought a roll and used the old nuts . I bought a cheap flairing tool at Napa but then I went to the Eastwood booth and the guy bent and flaired the line for me . After I did one double flair I bought the tool
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-05-2023, 08:55 PM   #3768
zicc1835
zicc1835's Avatar
x3 on this tool....
Old 05-05-2023, 09:30 PM   #3769
1967GMCC20
1967GMCC20's Avatar
Drove it........ to the Dollar Store.
1967GMCC20 is offline   Reply With Quote
Old 05-06-2023, 08:56 PM   #3770
72c20customcamper
New bumper came today did a test fit prior to painting it. The fit is ok not factory but not terrible I did have to shim the brackets to make it somewhat acceptable . Don’t like the gap on the ends to the grill but if I pull it in the bumper hits the fender on both sides . Right side fits better than the left. Pretty much the way the bumper stamped is off . Ordered it from Jegs It’s a Golden Star brand most likely a rebrand
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-06-2023, 09:04 PM   #3771
yuccales
yuccales's Avatar
Heater core project done. The cables got lubed and now are very smooth. Test drove, no leaks or coolant smell. New blower motor works great. Was happy with the core. Did not have to fight with the "bales" or customize in any way.
yuccales is offline   Reply With Quote
Old 05-06-2023, 09:15 PM   #3772
zicc1835
zicc1835's Avatar
E Brake done finally
Old 05-06-2023, 09:47 PM   #3773
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Made some more progress on my bucket seat swap. Im waiting on some hog ring pliers I ordered, but got the covers onto the foam and all tied down. Also doing a little final fitment of the frames and the homemade risers to be all done with those so once I get the covers hog ringed on, they can go in for the final time.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 05-06-2023, 10:19 PM   #3774
zicc1835
zicc1835's Avatar
that's going to be sweet
Old 05-07-2023, 10:13 AM   #3775
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks good
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
