Old 05-07-2023, 08:46 PM   #1
Ziegelsteinfaust
How do air shocks work or operate
On my 69 4 door Nova I am using 3" drop springs from Hotchkiss, and I am likely to add lowering spindles to get another inch. As the true drop has not been far enough for my taste. Currently it's only a 1/2" lower then when the original springs were there.
So to increase my cars weight carrying capacity in terms of weight before the tail drags everything. I want to add air shocks to the suspension off a braced section of the subframe.
So I will have 4 shocks in the rear. The normal shocks will be KYB gas adjust.
If I add air shocks will they increase my cars shock dampening in the rear. Or do they only do that when air is added.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-07-2023, 08:50 PM   #2
PGSigns
PGSigns's Avatar
Re: How do air shocks work or operate
You will pretty much double your dampening of the shocks. Air shocks are regular shocks with an air bladder. I would look at doing something like an airlift setup over air shocks.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-08-2023, 12:12 PM   #3
Ziegelsteinfaust
Damn they were a easy fit.
Well I will look to some sort of sleeve bag or small bellows bag
