Old 09-21-2022, 12:05 PM   #426
Tempest67
Tempest67's Avatar
Re: Jans 53
since you asked, I find the white background fills the space better, but either way looks good.
Tempest67 is online now   Reply With Quote
Old 09-21-2022, 06:20 PM   #427
olcarguy
Re: Jans 53
It's whatever your little old heart desires..... I like the white letters.
olcarguy is offline   Reply With Quote
Old 09-21-2022, 07:47 PM   #428
57FleetsideC4
Re: Jans 53
Originally Posted by 8man View Post
i'll be the contrarian, i like the letters white. Nice colors.
x3
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 09-21-2022, 10:54 PM   #429
NorCalGal
NorCalGal's Avatar
Re: Jans 53
I’ve decided on the white letters
Jan's 53
NorCalGal is offline   Reply With Quote
Old 09-25-2022, 09:14 PM   #430
joedoh
joedoh's Avatar
Re: Jans 53
I'll be the contrarian, I like the letters white. Nice colors.
add me to this
Old 10-02-2022, 10:23 AM   #431
my56chevytruck
my56chevytruck's Avatar
Re: Jans 53
I like the white letters moreso, my .02
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 04-05-2023, 08:56 PM   #432
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Back to work on the truck this week. The weather is finally drying out after a lot of rain this year. Getting around to redrilling the ford 8.8 axels to accept the Chevy 4 3/4 bolt pattern.
Jan's 53
Old 04-06-2023, 10:14 AM   #433
youngrodder
youngrodder's Avatar
Re: Jans 53
Much better. You don't want a Furd bolt pattern on that Chevy...Lot more wheel choices at 4.75 I imagine. That is what I'm running as well.
I'm looking forward to a driving weather forecast here in MI.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-06-2023, 10:21 AM   #434
dsraven
Re: Jans 53
nice work.
when I did an 8.8 flange pattern change I used the cut off flange from an old brake rotor thatcame with the axle. cut the rest of the rotor off so all I had was the actual part that touches the axle flange. took that to a buddy who has a lathe and he marked and drilled 1/8" holes where the chevy pattern would be between the ford pattern. then i bolted that onto the axle-it fits perfect because it was made for the axle- then quickly drilled through those 1/8 holes to make a dimple on the axle flange. removed the pattern, center punched the axle flange and drilled a pilot hole, then a hole the correct size for the wheel studs. press in the studs and done deal. I kept the pattern for future reference ot to lend to the next guy doing the same thing. having it referenced on the lathe makes for a perfect fit. a cardboard or plastic pattern would also work. how did you reference yours?
Old 04-06-2023, 03:34 PM   #435
dsraven
Re: Jans 53
I did mine while it was in the axle housing on the truck. not easy to get those new studs in there, lol.
I am jealous of your vice grip array. I have a whack of them too but you can never have too many. haha.
nice work, keep posting, it motivates some of us that need it.
Old 04-06-2023, 11:44 PM   #436
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Pretty simple job, just time consuming. I ordered a template from summit and used a transfer punch to mark for new holes. The hardest thing was getting the transfer dead on, just took my time. Did have to take a hole saw to open up the hole in the center of my drill press table so I could fit the axle through.
Today I made new leaf spring perches so I could move the perches a 1/2 inch to line up with the s10 leaf springs. Most people say you don’t need to and that it’s close enough. I guess I just can’t live with that so I’m moving them.
Bought myself a new tig welder last month been playing with it trying to get dialed in. I always used a big old miller of my friends. It was pretty simple you know a/c d/c. This one has a lot more options like balance, pre flow, post flow blah blah blah so it taking a little time to learn this machines settings.
Jan's 53
Old 04-07-2023, 12:04 AM   #437
dsraven
Re: Jans 53
I'm jealous of you for getting a new tig. I been looking at several, can't decide if multi purpose or dedicated tig only. I already have a mig and an arc welder, separately. What model did you go with? Air cooled torch or water cooled? Foot pedal or finger tip control? Inverter? Yep, lots of questions. Haha
Have fun learning.
Remember not to heat up the axle tubes too much when cutting, grinding or welding as they can warp/bend on you.
Old 04-07-2023, 09:00 AM   #438
8man
Re: Jans 53
Nice work Jan, glad you were able to get back on the truck.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 04-07-2023, 02:20 PM   #439
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Hey Robert, I’ve still been keeping track of your builds while trying to get motivated on mine. Love the color on the finished truck.
Dsraven don’t be too jealous it’s only a 205 dedicated Vulcan tig from harbor freight. The price was right and it actually has good reviews on you tube. I have no complaints so far, it’s probably even more than I need. I have a mig so no need for a multi use unit. It does do stick but I haven’t done stick before so I guess eventually I’ll have to give that a whirl.
Jan's 53
Old 04-07-2023, 09:40 PM   #440
dsraven
Re: Jans 53
well, it's 100 percent better than my tig right now. if it does the job then it;s good. electricity doesn't recognise a brand name
Old 04-08-2023, 11:24 PM   #441
joedoh
joedoh's Avatar
Re: Jans 53
nice work!
that was gonna be my question!
Old 04-09-2023, 10:31 PM   #442
NorCalGal
NorCalGal's Avatar
Re: Jans 53
https://www.summitracing.com/parts/mfy-8021392
Jan's 53
Old 05-07-2023, 10:08 PM   #443
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Went back to working on my doors this week. It was a long and wet winter and I spent too much time looking at things that could be done better. I ground down the edges of the door until the gaps were centered and even then welded them back up and metal finished.
Jan's 53
Old 05-08-2023, 09:27 AM   #444
8man
Re: Jans 53
Very nice gap.
Glad to see you back at it.
8man-aka Robert
Old 05-08-2023, 01:01 PM   #445
youngrodder
Re: Jans 53
Unfortunately there are no short cuts for great body work and nice gaps...Looks like a lot of hrs there.
Marc
Old 05-08-2023, 11:49 PM   #446
joedoh
joedoh's Avatar
Re: Jans 53
nice patient work jan! I would have already hit it with a sledgehammer.
Old 05-09-2023, 10:49 PM   #447
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Thanks guys.
Believe me a sledgehammer has been my solution to many problems, but I’m trying to take a deep breath in my old age.
Jan's 53
Old 05-10-2023, 07:25 PM   #448
NorCalGal
NorCalGal's Avatar
Re: Jans 53
Well a small step forward today. Trying to keep myself motivated by boring everyone else with these little achievements. As always pictures too!
Jan's 53
Old 05-10-2023, 08:42 PM   #449
olcarguy
Re: Jans 53
Nice job....Keep up the good work.
Old 05-10-2023, 10:18 PM   #450
Getter-Done
Getter-Done's Avatar
Re: Jans 53
Thumbs Up
The early bird gets the worm,
84 Chevy K-20
