Old 05-10-2023, 05:04 PM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
How to adjust engine hood
can anyone offer advice or ideas on how to adjust the back of the engine hood to sit flush with the fenders?? not sure how to adjust the back of the hood to lower down??
thanks!!
rodstored-72 is offline   Reply With Quote
Old 05-10-2023, 06:43 PM   #2
kwmech
Re: How to adjust engine hood
What year? There were a couple different hinge styles
Old 05-11-2023, 12:16 AM   #3
rodstored-72
chevy truck fan
ooppss... sorry..... this would be related to late model trucks... in my case it is for a 1986 hood...
thanks!!
Old 05-11-2023, 03:43 AM   #4
mongocanfly
mongocanfly's Avatar
Have you tried loosening the bolts that are thru the hinge, and into the hood? Those holes are oversized and slotted for adj..
Is it both sides or just the 1 side?
You could also possibly have bent hinges as well..has it always been this way,,or just recent?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-11-2023, 07:44 AM   #5
TKCR
TKCR's Avatar
Mongocanfly is correct. I swap out my hood and it was high in the back like that. And those are the bolts in my picture that are circled. Loosen those up and pull the hood down, and tighten.
Last photo is after the hood was painted.
Old 05-11-2023, 11:04 AM   #6
rodstored-72
chevy truck fan
guys.. thanks for the responses.. I will try those bolts to adjust. I will follow up on here as well, so hopefully it will help someone in the future too!!
thanks again for the responses...
Old 05-11-2023, 04:49 PM   #7
LS short box
So the pic of the bolts shown wouldn't they be for front to back adjustment?
On my 68 the hinge fender bolts are the ones that affect the level at the back of the hood.
To get the hood to set lower on my 68 at the back loosen the back bolts on either side and slightly loosen the front bolts. Then push the front of the hood up and tighten the bolts. Close the hood slowly because will cause the hood to move back a bit.
Old 05-11-2023, 07:17 PM   #8
mongocanfly
it does allow for front to back, and also up and down.. the 86 differs greatly from your 68
on the 86, the hinge mounts to a flat horizontal surface.. its possible you could shim the 86 up at this point..but not down
Mongo...aka Greg
RIP Dad
RIP Jesse
