Old 05-13-2023, 07:33 PM   #1
forestb
forestb's Avatar
I just avoided a catastrophe
I am installing a hydroboost unit on my truck and I had my front driver side wheel off to remove the hoses from gear box and while I had the wheel off I thought I might look into the rattling sound I have been hearing. It sounds like change rattling in a can when I went over bumps. I found a large washer in the bottom cup for the coil spring in the lower control arm. I have a 77 front cross member. I looked for where it came off of and this is what I found. I am not sure if it would have ever completely fallen apart but I thank God. It didn’t. It was a complete upper control arm that I bought from CPP years ago. Now I just need to find a replacement bolt and find out what they should be torqued to.
forestb is offline   Reply With Quote
Old 05-13-2023, 07:43 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: I just avoided a catastrophe
Wow, that's pretty unnerving! How's the front tire wear look?
~Steven
Simi Valley, CA
Old 05-13-2023, 07:46 PM   #3
forestb
forestb's Avatar
I have not even noticed any unusual wear. A while back ago I was having trouble trying to figure out why my turn radius was messed up. The mechanic was able to mess with the alignment to get it to work right but I wonder if this was the problem. I have been hearing the rattling for probably over a year so it may have been like this for quite a while.
Old 05-13-2023, 08:56 PM   #4
Warrens69GMC
Warrens69GMC's Avatar
That's scary.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 05-13-2023, 09:48 PM   #5
AcampoDave
AcampoDave's Avatar
Call me compulsive if you like (I am) but I freak out about rattles and such and will not let it go. Sometimes, like in your case, it's warranted. My worst cases were shock studs, a loose rear brake shoe...stuff that wouldn't kill me.... No joke, I once tore my whole dash apart only to later discover the cowl was chirping on the back edge of the hood. Oh, and the time I got mad and pulled off the whole door to later discover the seat adjustment mechanisim was lacking a tension spring. But let's face it, rattles and squeaks are often a sign of a problem waiting to happen, and they can be hard to locate. Glad you found that one when you did.
AcampoDave is offline   Reply With Quote
Old 05-14-2023, 09:13 PM   #6
forestb
forestb's Avatar
I searched under the truck fairly well in the past but didn’t find anything. I have had bolts fall down into the collar in the past so I just figured that was the problem again. Who knows. I might get it all put back together just to find out that that wasn’t even the noise.
Old 05-14-2023, 09:34 PM   #7
Lost in the 60's
Lost in the 60's's Avatar
I HOPE that arm wasn't hanging off the end of the shaft when it was aligned or the man was blind. I can see the shims in the pic...he HAD to have seen the arm if it wasn't in place while doing that.
I bought a front disc brake conversion from cpp several years ago and sold most of the parts at swap meets, as I considered them scrap. I will never will buy anything from them again. All chinese junk.
The original nut was a tension nut with crimped head to prevent backing off. IF the threads are imperial (USA), you can get original stye replacements and not worry about them coming off again.
Lost in the 60's is offline   Reply With Quote
Old 05-14-2023, 09:46 PM   #8
Getter-Done
Getter-Done's Avatar
Some one was Looking out for you.
Please continue with info like this.
Thanks for Sharing
The early bird gets the worm,
84 Chevy K-20
Old 05-15-2023, 08:35 PM   #9
forestb
forestb's Avatar
Thanks for Sharing
Yes he was.
Old 05-15-2023, 09:00 PM   #10
forestb
forestb's Avatar
I don’t really understand how they missed it either unless I am mistaken and the bolt backed out after they looked at it and the turn radios being off had nothing to do with it. All in all I have been pretty satisfied with cpp so far. I have had their drop spindles on the track for many years.
Old 05-15-2023, 09:23 PM   #11
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
please say you dont have a ground wire connected to the bolt on the rag joint bolt... (thats what it looks like though)
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 05-16-2023, 07:57 AM   #12
raidmagic
raidmagic's Avatar
Wow, that's crazy.
1965 C-10 1/2 ton shortbed part time daily driver
1980 C-10 1/2 ton shortbed project
raidmagic is offline   Reply With Quote
Old 05-16-2023, 03:39 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
Doesn't go to ground, it connects the upper shaft to the lower for horn relay grounding.
~Steven
Simi Valley, CA
Old 05-16-2023, 09:55 PM   #14
Getter-Done
84 Chevy K-20
Old 05-16-2023, 09:58 PM   #15
Steeveedee
Who Changed This?
Steeveedee's Avatar
Sometimes, I get one right.
~Steven
Simi Valley, CA
Old 05-24-2023, 11:07 AM   #16
MikeN
MikeN's Avatar
Same thing happened on my 65 Impala last year. Scary, for sure. I got lucky, no damage to the car, just had to get parts and re-attach the upper control arm. A previous owner had put aftermarket control arm bushings on my Impala, which I think created the problem.
MikeN is offline   Reply With Quote
Old 05-25-2023, 05:49 AM   #17
Android04
Android04's Avatar
Someone was watching out for you for sure. Hope this helps!
Android04 is offline   Reply With Quote
