![]() Join Date: Apr 2005
Power steering leak
I’m getting a power steering leak on the high-pressure hose where the AN the adapter fitting screws into the steering box. It only leaks if you turn the steering all the way to the stops. It’s 93 Silverado with an L86/8L90 swap, Holley mid mount accessory drive setup, has the factory steering box with Russel AN o-ring adapter fittings. I’ve tried 3. None have leaked while driving with normal steering, but if you take it to the stop for more than a few seconds, it leaks profusely. I’m not sure what’s going on. I'm going to try to go to NAPA this morning and see if they have any solutions. Any help or suggestions would be appreciated.
PS. I know this is not a squarebody, but the engineering is the same and you guys are more responsive than the OBS page, ![]()
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: Dec 1999
Re: Power steering leak
I used this one - https://www.amazon.com/gp/product/B08SR39Q7C/
I thought I had to where it wouldn't leak, after repeated tightening, now almost a year later I saw a drop on the crossmember. If you look at the only bad review for that item, it's about leaking. I was going to try to get a different hose made that doesn't use an adapter. I think I may just be crushing the o-ring while trying to get the inverted flare to seal... |
Bad bypass/relief valve?
#4 | |
It's hard to tell from the pictures, but it looks like the o-ring won't seal on the adapter. On the original line the o-ring is compressed by the hard line which doesn't move, but the adapter doesn't have a line so the fitting twists on the o-ring distorting it. Maybe try Teflon tape?
![]() ![]() Join Date: May 2015
The oring on the original is smaller than the 2 adapters isnt it?.. I'm thinking it may be a seating issue in the steering box...it holds until the pressure gets high as in full lock steering..
Kinda go along with what Sean says.. when you tighten those adapter fittings, its twisting the oring, where the factory fitting just puts pressure on the oring
#6 | |||
Possibly. Quote:
