Old 05-17-2023, 08:22 AM   #1
Tomo
Dana 44-8F
My 70 k5 has drums all the way around and I want to convert it to front discs.
I bought a front diff that has 44-8F in the casting. The overall width is greater than that of my current Dana 44. Any one know what this is out of?
My plan is to swap from the knuckles out only - anyone know if I will run into any compatibility issues?
Tomo is offline   Reply With Quote
Old 05-17-2023, 10:08 AM   #2
Tomo
Re: Dana 44-8F
Been doing a little searching. Is it possible this is a 3/4 ton 6 lug Dana 44?
Old 05-17-2023, 10:29 AM   #3
Tomo
Re: Dana 44-8F
I will need to get the id numbers off it when I get home.
Found this very helpful:
https://media.spicerparts.com/cfs/fi...store=original
Old 05-17-2023, 10:47 AM   #4
mongocanfly
mongocanfly's Avatar
Re: Dana 44-8F
i think the axles are the same.. only the outers are the difference between 1/2 and 3/4 ton
im assuming yours is open knuckle..
when you go to disc be sure to swap your master cyl to a disc/drum version
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-17-2023, 02:13 PM   #5
b454rat
Re: Dana 44-8F
6 lug to 8 lug, the axle itself is the same. 8 lug is wider, not sure exactly where, either hub bearings or rotor combo.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 05-17-2023, 02:56 PM   #6
Tomo
Re: Dana 44-8F
The width is what has me confused. The housing from C-C is wider.
I’ll post some measurements when I get home.
Old 05-17-2023, 04:40 PM   #7
Tomo
Re: Dana 44-8F
603675 = 1976 1/2 ton Chevy
C-C = ~56.5”
My 70 c-c= ~54.25”
That’s from the top of each housing.
