Old 06-09-2018, 02:42 AM   #1
Man With A Gun
Man With A Gun's Avatar
Premium diesel fuel: is it worth it?
Or does it cause problems?
77 Chevy K20 Longbed
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Man With A Gun is offline   Reply With Quote
Old 06-09-2018, 10:59 AM   #2
Man With A Gun
Re: Premium diesel fuel: is it worth it?
Premium diesel fuel around here costs 45¢ more per gallon than the regular stuff.
Has a higher cetane rating and more detergents. I'm curious what you other diesel fuel folks are buying, and what you try to avoid when out on the road on a long trip.
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Old 06-10-2018, 01:30 AM   #3
Man With A Gun
Nobody?
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Old 06-10-2018, 09:03 AM   #4
SKR
I wouldn't bother with it. I don't have any science to back that up, but I've never felt let down by regular diesel. I wouldn't expect premium diesel to have any difference in power that you can feel, and mileage varies so much depending on load, terrain and weather that I don't think you'd be able to measure an increase.
2007 GMC 2500 CCSB LBZ
1991 GMC 1500 RCSB 350
1981 GMC Street Coupe RCSB 454
SKR is offline   Reply With Quote
Old 06-10-2018, 09:30 AM   #5
rideair
Yes, I've used and have two friends as well.
Myself and one friend like it in our 2000/2002 F250 7.3 diesel, more pep, a little better mileage.
My other friend will only use it if he plans to run it out quickly and not let it for a long period of time. He claims, the higher cetane diesel will grow algae clogging up filters, etc... if it's allowed to sit for a long time (a year or more).
I've also heard the higher cetane stuff both "off-road" and "on-road" will work great in your household furnace to heat your house in the winter time!
Were I live, Southern States sells the 50 cetane for the same price as others do the regular stuff, so we fill up whenever passing by, but don't go out of the way to get there.
Hope this helps,
rideair is offline   Reply With Quote
Old 06-10-2018, 10:14 AM   #6
Man With A Gun
Thanks for the help guys.
I'd never heard of the stuff until I bought this diesel Dually. There is only a few places to get ethanol free which is what I use in my gassers. When I got this diesel I went to the station I normally use and the premium diesel is all they had.
It does seem to get about 10% better mileage than the other cheaper stuff. That's just a guesstimate. Haven't tried it under load yet.
For an extra $14-15 per tankful I don't know if I'll keep buying it.
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Old 06-10-2018, 12:37 PM   #7
68longhorn
68longhorn's Avatar
Make friends with a transmission shop and get all their old atf. Filter it and run that.
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 06-13-2018, 08:21 PM   #8
DieselSJ
Bad idea. ATF was not designed to burn and leaves lots of soot and ash and carbon.
Run regular pump diesel and add about 1/2oz of 2-stroke oil per gallon of diesel and NO other additives. It has been proven several times that this more than makes up for the lack of lubricity from removing the sulfur. You pump and injectors will love you for it.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 06-15-2018, 01:12 PM   #9
Tom
driving is in my blood
Tom's Avatar
I fill up cars at least 4-5 times a day for work. I've never even heard of different diesel fuels. Mind = blown.
Old 06-16-2018, 01:43 AM   #10
kwmech
Marvel Mystery oil is also a good additive
Old 06-16-2018, 07:46 AM   #11
buffydores
buffydores's Avatar
Hope this helps,
If it has some of the bio-diesel stuff in it, your friend is right. It will grow algae. We had this problem with our tanks at work. We actually switched vendors over it because the vendor was adamant that it wouldn't. We battled with them for the years over the matter. Haven't had an ounce of problems since going away from bio diesel.
Old 05-18-2023, 10:08 AM   #12
j hannah
comfortably numb
j hannah's Avatar
I deliver fuel, I work out of the Tulsa area. The bio in the diesel is mostly used fryer oil from restaurants. It is filtered and they have it in a separate tank by the loading rack. We load it first, usually about a 10% mix if I remember correctly, then pull on the rack and load the diesel into it. It mixes as it loads so they say. I won’t run it in my personal truck (84 k1500 with a 6.2). My truck sits for extended times, and it will clog the fuel system. Beware where you buy your fuel if you don’t want bio. Some stores only place small decals on the dispenser stating it contains bio. Large truck stops like pilot/flying j, loves and t/a have onsite bull bio tanks and blend it onsite.
1974 gmc 3/4 t. c/s
1974 chevy k-10
1973 pontiac grandville(turnpike cruiser)
j hannah is offline   Reply With Quote
