#26 | |
Professional Grade
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#27 |
Stepsides RULE
lemme guess, the teeth in the sleeve stripped out?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
#28 |
i just tore my dash apart and installed a tach - while i was at it i cleaned everything, put new bulbs (194s dangit i wish i knew others fit!) and did the paint trick it looks alot better i must say! im thinking of buying these white lights on http://www.superbrightleds.com/cgi-b...gi?product=CAR
might look not so yellow |
#29 |
THe guy at superbright LEDs has a good product. I replaced the side marker, tail lights and front flashers. The only issue I see with the 192/168 replacement is the narrow dispersion, not like a regular bulb. my side markers look like dots, albeit very bright dots. when i got mine, he didn't have any of the 30 LED ones, i have the 19s. very bright though.
I finally got my 1977 bezel disassembled, and am going to both upgrade to 168 bulbs and paint it with chrome. also need to polish the lens too. I found mag polish like blue magic does wonders on plastic. I may as well repaint the faded needles on the gauges too. time to get some paint at the hobby shop for the old airbrush. ![]() ![]() ![]() |
#30 |
www.loweredd.com
I also painted mine AND installed 168 bulbs. HUGE difference. I might use those 3652's that were mentioned. I can get Wagners here at work for 2.67 a piece. I used 3M plastic polish on the front too.
A little time on the gauges is worth it!! |
