Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 05-20-2023, 03:05 PM   #1
dmjlambert
dmjlambert's Avatar
What is the right tool to cut this PVC pipe?
You folks that are handy with landscaping and ditch digging may be able to help me here.
This big pipe is 4 inch fairly thin-walled yard drain pipe. I am re-routing it. I need to cut out a section of it, and then I will no longer use the section that is going off to the right. I will connect a 45 degree elbow on the section going off to the left and lay new pipe in my new empty trench.
What is a good thing to cut that big pipe with? It is in a somewhat tight spot and I need to leave the smaller sprinkler pipes undamaged. I would normally just use a hacksaw, but that is only an option if the pipe were much more accessible.
Old 05-20-2023, 03:18 PM   #2
Getter-Done
Getter-Done's Avatar
Re: What is the right tool to cut this PVC pipe?
This is the first this that comes to mind.
Link: https://www.homedepot.com/p/Milwauke...kAX4MTdzU-sRA0
It does not look like you have room for that without a lot more work and digging.
What about a saws-all
Link: https://www.homedepot.com/p/Milwauke...1-20/205482388
Sorry I am a Milwaukee addict
The early bird gets the worm,
85 Chevy K-20
Old 05-20-2023, 03:24 PM   #3
MySons68C20
MySons68C20's Avatar
Long blade on a Sawzall or Dewalt cordless (easier imho) cut from the building out and use a chunk of plywood or whatever to protect the 1" irrigation lines.
MySons68C20 is offline   Reply With Quote
Old 05-20-2023, 03:45 PM   #4
68bowtie
68bowtie's Avatar
Hack saw
Edit: Guess I didn’t read far enough, ignore me!
Old 05-20-2023, 03:51 PM   #5
kwmech
masonry String/Line
https://www.youtube.com/watch?v=146SwnF5qZY
Old 05-20-2023, 03:59 PM   #6
MySons68C20
Originally Posted by kwmech View Post
Dang Jina, that is cooll!
Old 05-20-2023, 04:00 PM   #7
Getter-Done
Wow That will work.
I got a windshield removal tool that i bet would work also.
Link: https://www.harborfreight.com/profes...kit-96339.html
85 Chevy K-20
Old 05-20-2023, 04:05 PM   #8
weq92f
weq92f's Avatar
What? No waaay!
LOL
https://www.youtube.com/@whatnooowaaay
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-20-2023, 04:09 PM   #9
mongocanfly
mongocanfly's Avatar
I always use a sawzall..like said, protect the small pipes and you'll be fine
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-20-2023, 04:14 PM   #10
Dead Parrot
Variable speed sawzall with a fine tooth metal cutting blade. Plus as already mentioned, something to protect the smaller lines. Assuming the small ones are plastic water lines, not the worst oops if you cut one. Couplers are low cost.
Dead Parrot is offline   Reply With Quote
Old 05-20-2023, 05:03 PM   #11
dmjlambert
dmjlambert's Avatar
That is pretty cool trick with string. A comment on that video suggests to dip the string in primer to make it even quicker. Thanks for these ideas. I will have to go shopping. Hmm, an excuse to buy a sawzall, sounds splendid. For me it would have to be corded or air, no battery stuff for me beyond flashlights and one extremely rare plug-in screwdriver.
Old 05-20-2023, 05:09 PM   #12
Sheepdip
Sheepdip's Avatar
Originally Posted by mysons68c20 View Post
long blade on a sawzall or dewalt cordless (easier imho) cut from the building out and use a chunk of plywood or whatever to protect the 1" irrigation lines.
^^^^^^^^^^this^^^^^^^^^^^^^^^^^^^^
Sheepdip is offline   Reply With Quote
Old 05-21-2023, 06:44 AM   #13
I'd use a Sawzall and common sense protection of other pipes. The string method is neat, but that wasn't a good cut for coupling, way out of square
Old 05-21-2023, 09:19 AM   #14
joedoh
joedoh's Avatar
I have used this on pvc and it worked great.
funny story (depending on your gag reflex). we bought a property for the 30x50 storage building but the city wouldnt let me tear down the house so we had to rehab it (another story). the PO fancied himself a remodeler and moved the sink from the back wall to an island. I guess they thought water drains worked on the principle of pressure, because where it came out of the floor was lower than the sewer main 12 feet away, and to make it worse there was a dishwasher and a garbage disposal hooked at the sink, so lots of food in the line.
some incredibly lucky fool (me) got to raise the line and change the angle to drain.. access in the floor joists was tight and so i used the abrasive string shown.
the line was still full of water (and food scraps) and had sat for 3 years withe the house empty. I cant forget the smell. when my mother in law moved in she would not stop mentioning the smell. it eventually faded but good. lord.
Old 05-21-2023, 01:39 PM   #15
kwmech
I worked on a horse ranch for a number of years and this is how I repaired the sprinkler lines in the pastures after the horses would play and bite the sprinkler heads. We finally would move them while we watered, but I would cut the lines with the string and repair. We tried to keep the holes in the pasture as small as we could before we tamped them back down. Braided mason line works the best
Old 05-21-2023, 04:18 PM   #16
72c20customcamper
72c20customcamper's Avatar
This would work also . I got one a few years ago for Father’s Day and I’m surprised how much I use it . They make corded versions too
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-21-2023, 04:19 PM   #17
dmjlambert
dmjlambert's Avatar
I ended up getting a wire saw at Lowes, and used a close-quarters hacksaw to start the cut.
Old 05-21-2023, 04:36 PM   #18
jaros44sr
jaros44sr's Avatar
Originally Posted by 68bowtie View Post
Hack saw
That was my first thought as well
I was so excited about having an answer, I stopped reading, until I saw your post
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-21-2023, 06:15 PM   #19
best view
That would be a plumber while you watch with a cold one
best view is offline   Reply With Quote
Old 05-21-2023, 10:11 PM   #20
Getter-Done
Good to Hear that you got it like you want it
Now
Answer me This
How can you dig a trench/ditch ,
Then put a pipe in it That was not there before.
Save the Dirt that came out of it.
Then you will need More Fill dirt to make it level again.
85 Chevy K-20
Old 05-21-2023, 10:23 PM   #21
dmjlambert
dmjlambert's Avatar
yes, I will be needing more fill dirt, I just stomp it down too hard.
plumbing, sprinkers
