Old 05-23-2023, 05:24 PM   #4
Just call me Sean
Just call me Sean's Avatar
Re: Hard to time
33 is MAP sensor, it won't run very well if that's bad. Make sure it's plugged in and the vacuum hose is still attached on both ends. 42 is EST, which you will get from disconnecting the bypass to set the timing. You have to clear the computer after setting the timing to clear the 42. If you did clear the computer, then the bypass might not be making a connection from corrosion.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
