Old 05-23-2023, 06:32 PM   #1
weq92f
weq92f's Avatar
Gonna cost me more $$
Working on converting from r4 pancake to Sanden unit and decided I needed to service my radiator...maybe even take it to a shop for a go-through. It's a 4 row brass/copper unit and is of unknown age.
While removing it, I broke off the heater feed line barb. What would you guys do? Allow a shop to clean and repair this radiator or purchase a new one?
The BBC this thing cools runs right at the top of the range temp wise and creeps up at idle with A/C running. My best guess is that it runs at about 220 to 230...that's why I was considering having a shop refurbish it.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-23-2023, 06:56 PM   #2
72SB
Re: Gonna cost me more $$
Well if its original and you want to preserve that than have it serviced.
With that said a modern design radiator using fewer but larger cores (2 row 1 1/4-1 1/2") will cool better than a 3-4 row with smaller cores.
running hot while moving at hwy speeds indicates a clogged system. getting hot in traffic, stop & go, indicates not enough fan and or shroud.
7 blade fan with fan clutch
My $.02 on a replacement radiator is Cold Case. You can paint them black if you want them to look more original. I know they typically copy side tank stampings from original.
72SB is offline   Reply With Quote
Old 05-23-2023, 07:24 PM   #3
dmjlambert
dmjlambert's Avatar
I suggest clean and repair.
Old 05-23-2023, 08:05 PM   #4
Lost in the 60's
Lost in the 60's's Avatar
Check prices on a replacement and you may well be looking for a reputable repair shop, if any still exist in your local. Repair shops have all but disappeared around me. I can't find a copper/brass rad for my '89 C3500, they have all gone to aluminum.
Soldering that nipple back on is no big deal for a shop. They will, most likely, remove the tanks to rod out the tubes, or suggest replacing the whole core.
Lost in the 60's is offline   Reply With Quote
Old 05-23-2023, 08:05 PM   #5
HO455
HO455's Avatar
Personally I would I would repair it if possible. As stated creeping up at idle or in stop and go traffic usually means more air flow is needed and a shroud to make sure the air is being pulled through the entire radiator.
What are your current fans rated at? At what voltage?
When you say it's running at the top of the range is that with the factory guage?
If it's the factory guage it may have had this happen.
https://67-72chevytrucks.com/vboard/...d.php?t=840259
RIP Bob Parks.
Old 05-23-2023, 09:04 PM   #6
dmjlambert
dmjlambert's Avatar
I liked Bill’s Radiator & Muffler on K Ave in Plano when I lived there. They did a good job for me at a reasonable price. It took them a couple weeks to work on my radiator, but I was pleased with their work and they seem to know what they're doing.
Old 05-23-2023, 09:33 PM   #7
weq92f
weq92f's Avatar
The fans are generic "Pro Series" fans that draw 12 amps and are rated at 1200 CFM each. Both shroud and fans were purchased from ChampionRadiators.com. The creep only occurs with the A/C running. I can switch off the A/C and watch the thing cool down rather quickly. The "shroud" mounts the fans about 1/2 inch above the fins.
I'm estimating the temp based on an aftermarket Classic Instruments gauge that gets its reading from the intake mounted sensor.
-klb
Old 05-24-2023, 09:25 AM   #8
MARKDTN
I would also have your radiator fixed.
As far as fans, looks like they have a decent shroud to get all the air so that's good. I have never been impressed with aftermarket fans. I'm sure decent ones exist but I have not had any. There are some very good stock ones out there-C4 and C5 Corvette, 3rd and 4th Gen Camaro have dual single speed. Ford 3.8 Taurus/Sable and Lincoln MK VIII and some Volvo have big single 2 speed fans. 2000ish Contour has nice dual 2-speeds. There is a Jeep Cherokee fan that is well regarded too.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-24-2023, 10:06 AM   #9
72SB
On this and other forums there are countless threads about EL fan issues. In general, most do not pull enough air, especially on AC cars as the additional condenser is in front of radiator. Hi $ brushless fans have been the solution.
OP's note his most trouble is while using AC which would indicate his current EL fans are just not enough. This coupled with a radiator that may not be flowing as well if it should if his is old would compound the problem.
If temp gauge sender is in intake manifold, head sender would show even a higher temp
If EL fan setup has adjustment to turn on fans at lower temps, I would set it lower.
Old 05-24-2023, 01:19 PM   #10
HO455
HO455's Avatar
The problem with many lower cost fans is the advertised CFM rating is achieved at 14 or 16 volts. In the real world where they are running at 13.5 to 12 volts the CFM they move is lower.
In my opinion 2400 CFM is the lowest I would use on a 400 cubic inch stock engine. On my 401 AMC which is around 310 hp at the rear wheels I have four 1200 CFM Spal fans using a 2 row 1 inch tube aluminum radiator to keep it cool in traffic all year long.
RIP Bob Parks.
Old 05-24-2023, 01:54 PM   #11
Willie Makeit
Willie Makeit's Avatar
repair it, it's a 5 minute braze job
Willie Makeit is offline   Reply With Quote
Old 05-24-2023, 02:04 PM   #12
weq92f
weq92f's Avatar
Thanks everyone!
I'll be dropping it off at a local shop today for repair.
I agree with you guys...the fans I'm running are likely not moving enough air. I'm looking at a pair of these as replacements...
Spal, Electric, Single, 14.00 in. Diameter, 1,864 cfm, 12 V, Puller
At 172 bucks each they are not cheap but their rating is definitely more true than the generic fans currently installed. I suspect the drop in CFM at normal voltages and under pressure isn't as drastic as the generics either.
-klb
Old 05-24-2023, 03:24 PM   #13
Jason Banks
Jason Banks's Avatar
I've got a pair of these on an LS Swap 6.0 and have had no issues:
https://www.amazon.com/gp/product/B009OBOSTU/
Jason Banks is offline   Reply With Quote
Old 05-24-2023, 04:57 PM   #14
HO455
HO455's Avatar
It's not apples to apples comparing an LS to a Gen 1 BBC. The efficiency of the LS engine is so much higher. This means more of the cylinder heat goes out of the exhaust and thus the cooling system has less heat to remove from the block. One reason they make more horsepower per cubic inch.
RIP Bob Parks.
Old 05-25-2023, 12:05 AM   #15
mr.mud1
mr.mud1's Avatar
sounds like you're having it repaired.it was soldered on from the factory,no reason why it can't be re-soldered.i do my own rads here and usually take those fittings off,clean everything and re-solder anyway,just to know they're in good shape.
mr.mud1 is offline   Reply With Quote
Old 05-25-2023, 08:30 AM   #16
Lost in the 60's
Another important part of electric fans I haven't seen mentioned is the gauge of wire and the relay rating. A small diameter wire will choke the fans ability to run at it's best, as well as a relay rated too low. Your new fans may well require an upgrade there too. I run my fans power direct from the battery, with a Dakota digital fan controller to set the on, off temps and to run after shut down.
Old 05-25-2023, 09:24 AM   #17
MARKDTN
Agree. My '01 Tahoe with 5.3 ate the seal in the water pump (at 240K miles). I happened in late July coming home from my parents house 200 miles away. We got home around 1:00AM. It was dark, but air temps in the high 80s so A/C on. I never realized anything was wrong until I got home and saw it was dripping. The temp gauge never went higher than usual. It was about 2 gallons low the next morning.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 05-25-2023, 02:52 PM   #18
weq92f
weq92f's Avatar
The relays and harness I used when the fans were installed were purchased from a board member here. I don't recall the amp rating on the relays but the harness itself was well made with appropriate gauge wire.
-klb
Old 06-02-2023, 05:26 PM   #19
weq92f
weq92f's Avatar
Local radiator shop cleaned, repaired and painted the thing. Cost was 88 bucks. Should receive the new spal fans today.
-klb
Old 06-02-2023, 07:03 PM   #20
cornerstone
cornerstone's Avatar
Good decision at a better than fair price too.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-02-2023, 08:53 PM   #21
body bolt
-klb
That's a steal.
body bolt is offline   Reply With Quote
Old 06-02-2023, 09:19 PM   #22
RenoKeene
Florida Edition
RenoKeene's Avatar
Interesting that the stock A/C setup from the factory on big block trucks actually worked...well sort of.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 06-03-2023, 07:58 AM   #23
Lost in the 60's
-klb
Wow, I couldn't get the one local guy to repair mine. He's retired and only works once in a while. He initially said anywhere from $150 to 250 to repair. You got a REALLY good deal there. I had to buy a new aluminum and fricken plastic tank rad for my truck. It does seem well built and cost $240, so wasn't a price difference from quoted repair.
Old 06-03-2023, 10:50 AM   #24
dmjlambert
dmjlambert's Avatar
There were a couple years where the copper/brass ones were not available or hard to find, but I see they are back and reproduced nowadays. About $450 to $900.
Old 06-03-2023, 11:30 AM   #25
72c20customcamper
72c20customcamper's Avatar
-klb
There’s only one shop around me that does radiator/gas tank repair . They won’t even look at it for $88 . They wanted $225 just to boil out the tank for my Chevelle . Didn’t give a price if there was a leak repair and another 75 to seal it after the repairs . I bought a SS tank from Ausley Chevelle at the spring Carlisle for 175 show special . They are 270 now
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
