![]() Join Date: Mar 2013
concrete sealers
Anyone have any suggestions or experience with any of the new concrete sealers on the market today? I have just had a new floor finished, and would like to apply a coating before we move forward with the rest of the framing. Thanks in Advance, Mike
Re: concrete sealers
I used Cure and Seal. I think there is a number after it but don"t remember it. It came in a blue I think 4 gallon can, used almost all of it on a 30x40 using a paint roller.
New concrete should cure at least 30 days before a sealer is applied As far as sealers go single component moisture cured clear is very popular and very durable. Top coated with a two-part polyester, is your most durable and expensive floor system. Then comes the epoxy from the big box stores cheaper but not as durable
I'm looking to seal concrete I had poured about a year ago.
Does anyone have anymore suggestions? Thanks |
I'm not an expert but have been told by many people that do concrete that for a sealer to last there needs to be a vapor barrier under the concrete. If not it will flake off over time. I used a cure and seal on my garage floors just after they were poured. I would use an etch on cured concrete before using any product on it. Again I'm not an expert but have built several garages.
![]() Join Date: Mar 2009
Just curious, is sealing concrete just to make it resistant to oil or is there another advantage? The concrete in my garage is insulated with a vapor barrier and was done about a year ago.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
Should help from staining it and help with sweeping
![]() Join Date: Mar 2003
What kind of finished surface are you working with?
Home Depot product called Behr concrete , masonry sealer
I've used it on the concrete around my swimming pool for years , doesn't peel , beads water , holds up decent even with the chlorine water that gets on it. Doesn't break the bank either Is there home Depot's in the USA ???? |
EVERYWHERE! Lol
![]() Join Date: Jan 2011
I used Euclid Diamond hard on my shop floor. It is a sealer and densifier. Been three years and happy with it. I do a lot of fabrication work and the surface is tough. Just added 500 square feet for a machine shop and used it this time also.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Jun 2022
I was always told to prep(power wash) and apply bonding compound("concrete bonding adhesive") before laying any masonry products on existing concrete.
There might be stuff built into the coatings that provides the same function, but I think I'd put the extra steps in before I layed that stuff down. Last edited by Rust_never_sleeps; 08-13-2023 at 04:20 PM. |
| Bookmarks |
