![]() Join Date: Feb 2020
Rear Air ride no frame cut
Hey guys looking at swapping coil springs for airbags not ready for complete airride setup yet..... Anyone have pics of air bags in rear without cutting and step notching their frames
1972 GMC |
![]() Join Date: Mar 2011
Re: Rear Air ride no frame cut
[QUOTE=Blazer Steve;9203031]Hey guys looking at swapping coil springs for airbags not ready for complete airride setup yet..... Anyone have pics of air bags in rear without cutting and step notching their frames
1972 GMC[/QUOTE hope these help
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Thanks Looking for the finalized ride height sorry should have been more clear... I think I have an decent idea of what I need though!
Steve |
![]() Join Date: Feb 2016
This is as low as possible fully aired out and if you remove the factory bump stops. Rear tires are 15/50/295's.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#5 | |
Anywhere in between is possible.
#7 | |
That was with the truck aired out frame sitting on the rear axle and hard on the front control arms.
#9 | |
So you'd want to know what set-up the person is using (parts, pressures, installation specs) to go along w/any images they provide to narrow down your choice. Beyond that, it's adjustable as you mentioned.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-15-2023 at 02:23 PM. |
#10 | |
#11 | |
It's one of those grey areas when info is shared. I try to make sure the 'requester' gets the logic of knowing all the variables for a certain stance when making their decisions pertaining to parts purchases. Those parts and/or their bracketry can make a difference. Keep us posted on the progress!
I measured my frame on my 71 with the bags aired out and its under 14.5 inches from the ground if that helps I don't have the step side bed back on it yet so no pictures available hope this dosnt muddy the waters........
