#1 | |
![]() Join Date: Dec 2009
Re: Np203
![]() Stuck at a Clay Pond (Becauce of a Snapped U-Joint) One axle not pulling = You are not moving ![]() There is plenty of info online about this now. There is a kit like this in the link below. You take the Spider gears out and use these Wedges to make it a Solid shaft.(Kinda) ![]() Link: https://www.summitracing.com/parts/mmk-501 They also make a solid shaft now. Maybe someone else has used these. I will try to find a link for the One piece shaft.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
