Old 05-20-2023, 08:28 PM   #1201
cwcarpenter98
cwcarpenter98's Avatar
Re: Frankentruck
Some days you win, some days you lose, some days you end up right in between.
Today is right in between.
Got the old transmission out on Thursday evening after work. Got the overdrive specific parts reinstalled to the overdrive transmission yesterday after work. This morning, I got the transmission back in the truck, then realized I forgot a crucial part. Yup, it’s gonna leak without the output shaft seal. At least I noticed it before I put gear oil in it. Finished up the swap this afternoon, went for a test drive and that’s where a little bit of sadness happened.
The good: shifts through all the gears, is much quieter, doesn’t make any crunchy noises
The bad: does not shift into overdrive, lockout cable is hanging up and won’t lockout unless I move the lever at the transmission end, gear oil is leaking out of one of the case bolts.
Not sure what the problems with the lockout cable and the overdrive are, but I’ve been working on the truck for about 9 hours today, so I’m throwing in the towel for today. Hopefully with a fresh mind tomorrow I’ll be able to figure it out.
On the test drive, I did see a really cool 64 F100. It has a 302 with a mild cam and a c4 auto. Sounds great and looks cool. I just love hubcaps and steelies
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 05-20-2023, 09:22 PM   #1202
straight6chevyguy
straight6chevyguy's Avatar
Re: Frankentruck
Sorry to hear about the overdrive not working Christian, hope you get it figured out, which I'm sure you will.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 05-20-2023, 10:17 PM   #1203
Arne
Arne's Avatar
Re: Frankentruck
Originally Posted by cwcarpenter98 View Post
Originally Posted by Arne View Post
What a coincidence! I got all these same parts today as well!
Good deal! I would say that I'll race you to get them all installed, but my guess is you'll be done well before I will
I think you were correct. But in addition to having a lot of time to play with the truck, I don't have a recalcitrant overdrive to fight with right now.
In any case, I'm about 80% or more done now. It's really a pretty good system, not hard to install. I should be ready to evacuate and charge it by Tuesday.
Feel free to PM me if you run into any questions when you get started.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
Arne is offline   Reply With Quote
Old 05-21-2023, 09:05 PM   #1204
cwcarpenter98
Re: Frankentruck
Thanks! Got to work on it some more today and figured out part of it.
I’m hoping that I’ll be able to start my install later this week, if the overdrive starts playing nicely…
Attempted to seal up the couple leaks I found today, but not test driving until tomorrow. Also tinkered with the overdrive electricals and found the contact points in the solenoid needed cleaning. Hopefully that does the trick!
Christian Carpenter
Old 05-27-2023, 09:40 PM   #1205
cwcarpenter98
Re: Frankentruck
The leaks seem to have been addressed, but the overdrive still won't engage. I've cleaned all the points for the relay, solenoid, and governor, but that didn't fix the issue. Hopefully I don't have any sort of mechanical misalignment issue. Drives really good as a standard 3 speed though, so I'll keep driving and maybe eventually the overdrive will work again?
Christian Carpenter
Old 06-08-2023, 07:03 PM   #1206
Darkrider
Darkrider's Avatar
Re: Frankentruck
I finally got this thread fully read, It Took a few days but eh. I started reading about Penny initially then saw mention of this truck, which turned into a "Squirrel!" moment lol.
'84 Chevy Custom Deluxe 10 "Frankenstein"
http://67-72chevytrucks.com/vboard/s...d.php?t=690587
'69 Chevy C10
Darkrider is offline   Reply With Quote
Old 06-08-2023, 10:06 PM   #1207
cwcarpenter98
Re: Frankentruck
Yeah, the thread has gotten fairly long, but that’s what happens with a drivable restoration. Thanks for tuning in!
Cleaned up the back work bench from the transmission rebuild yesterday and then laid out all the new parts. Spent a little time this evening taking apart the interior side of things. Next step was to disconnect the heater hoses, so didn’t feel like making a mess in the dark
Christian Carpenter
Old 06-09-2023, 02:50 AM   #1208
Darkrider
Darkrider's Avatar
Re: Frankentruck
I can def see why. Honestly, I am starting down this path with Frankenstein as it is. I have owned the truck for 9 years this coming September and really haven't put much into it other than the basics. It has been a good solid DD for most of that time. I honestly thought I would be further along with it by now but the only times I have parked it for a long period of time is over winter as I wasn't really a fan of driving it in the winters we get up here in Canada.
'69 Chevy C10
Old 06-10-2023, 10:10 PM   #1209
cwcarpenter98
Re: Frankentruck
My philosophy has been that they’re more fun to drive than to work on, so I try to keep mine drivable as much as possible. I missed driving it today to a swap meet, but it’ll be even more fun once I get the ac installed
Christian Carpenter
Old 06-10-2023, 10:23 PM   #1210
cwcarpenter98
Re: Frankentruck
Speaking of the swap meet, I found some neat stuff.
An aluminum 62 grille, 3 61-63 GMC nub style hubcaps, and the best part, a green gas cap. Not sure if it’s an original GM cap, but it is green and fits nicely, so I’m pleased. Even better that the gas cap was only $5
After the swap meet, dad and I went up to our farm to do a little work. Left a different way than usual and found a neat 61 C60 on a neighboring farm. It looked pretty rusty unfortunately, but now I kinda want to see if there’s any chance at saving some of the good parts left
Christian Carpenter
Old 06-10-2023, 10:45 PM   #1211
Getter-Done
Getter-Done's Avatar
Re: Frankentruck
Great finds at the swap meet.
That truck needs to be Saved.
I like those 61 hoods.
Wait is that Tow-Mater
84 Chevy K-20
Old 06-11-2023, 03:52 AM   #1212
Braunschweiger
Re: Frankentruck
Wow, I like these big trucks, great finds.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 06-12-2023, 10:50 PM   #1213
cwcarpenter98
Re: Frankentruck
I also like the 60-61 hoods, but prefer the 61 turn signal bezels over the 60. I would love to save it, but with no where to put it and really no need for it, it'll probably sit there for many, many more years
I do too. Maybe one day I'll be able to justify owning one. Would be cool to turn one into a car hauler so that I could take more than one old truck to a show
Christian Carpenter
Old 06-13-2023, 03:20 PM   #1214
Darkrider
Darkrider's Avatar
Re: Frankentruck
Reading through this thread has me wanting to go look for an older 60s C10 to go with my '84 lol. Ironically enough I found out that the liner I have in my '84 lists its application as 68-87 on its SKU sticker. Def food for thought if I were to either get my '69 home finally or pick up another '67-72 along the way.
'69 Chevy C10
Old 06-13-2023, 11:33 PM   #1215
cwcarpenter98
Re: Frankentruck
I want to get a 67-72 at some point so I can have all three body styles of C10s
Christian Carpenter
Old 06-14-2023, 10:54 AM   #1216
clemdaddy
clemdaddy's Avatar
Re: Frankentruck
That 60 2-ton grill might be worth another trip out there. Even if it doesn't fit a half ton it would make a great wall hanger and it looks complete. Gotta love swap meets.
clemdaddy is offline   Reply With Quote
Old 06-14-2023, 09:54 PM   #1217
cwcarpenter98
Re: Frankentruck
It's missing a bezel and headlight, but I would love to have it for a wall hanger. Maybe one day when I'm up there I'll get a chance to talk to the owner. Some of my best finds for Frankentruck have been at a swap meet. One of my favorite ways to spend a Saturday morning!
Christian Carpenter
Old 06-17-2023, 11:45 PM   #1218
cwcarpenter98
Re: Frankentruck
Some good progress has been made this week. The A/C switch was added to the factory control panel, old heater core removed, and then prepped under the dash for the new unit to be installed. Installed it this morning and then worked on mocking up the compressor brackets and pulleys.
A couple years ago, when I picked up the spare overdrive transmission, I also got the crank and water pump pulleys and the power steering pump and pulley from the 69 or 70 truck that the transmission came out of. I don’t think it was the original transmission to that truck. Anyways, the pulleys were a matching set, so I grabbed them. Turns out, that was a great move as they’re the exact pulleys I needed to add the a/c compressor. If I ever do decide to add power steering in the future, I already have the necessary parts.
Going to spend some time cleaning and painting the pulleys and painting the compressor brackets tomorrow. I need to get this done before heading to Lebanon, TN, for the Southeastern Truck Nationals
Christian Carpenter
Old 07-03-2023, 10:35 PM   #1219
cwcarpenter98
Re: Frankentruck
Lots of progress has happened since the last update. Mostly worked on the truck in the evenings after work, so it was slow but steady progress.
Employed the front yard paint booth once again to paint the compressor brackets and pulleys.
I was able to install the condenser without removing the radiator in an attempt to save my coolant, but alas, the old flex hose I had used when the radiator was in the incorrect inline 6 location, provided about a 1/4” of clearance to the fan belt. Picked up the correct, molded lower hose today and now have plenty of clearance.
Got the a/c and heater hoses ran in ways that shouldn’t cause issues with any other component, ran all the wiring, and added some rubber plugs to fill all the unused holes in the firewall and make some grommets for wires and the heater valve control cable.
Pulling the gauge cluster out made running the a/c ducting much easier to the vent on the left of the steering column. That also gave me the opportunity to replace the odometer roll that had locked up on me again with another one. Hopefully this one will last a long while.
On the glovebox, it did have to be shortened, but I didn’t like how short the box was going to end up if I had used the plastic end cap included with the kit. Instead, I made one cut on the box and re-folded it to shorten it up. That ended up working out nicely, so I’m pleased with that. Still have plenty of room to store stuff. I also spent a little time working on lining everything up properly on the glove box door. I would have to dig my fingers behind the door to pull it open beforehand, but now it functions as GM intended. Opens with one push of the button and doesn’t require digging behind the lid. Absolutely love that.
On the vents, I went a little unconventional in my mounting methods. I didn’t feel like attempting to drill holes somewhat accurately to install the vents, so I just used some 3m double sided fender emblem tape to mount them. Works great and didn’t have to drill any additional holes.
I did have to move the coolant/ windshield washer bottle up and to the driver’s side since the new ac and heater lines exit the firewall where the bottle was originally mounted. I was able to use the new system’s mounting studs to mount the bracket, just had to add a piece of metal and repaint.
I was able to test the system and the heat does work, but haven’t tested the a/c yet. I’ve got an appointment to get it evacuated and charged on Wednesday morning. Leaving for SETN on Thursday!
Christian Carpenter
Old 07-03-2023, 10:57 PM   #1220
Getter-Done
Re: Frankentruck
Sounds like Great progress to me.
I have a vacation day Friday.
Give me a call if you need any help along the way.
I resided close to the Lebanon SuperSpeedWay
Oh WWait it the Nashville superSpeedway
Looking forward to seeing you at the Show.
84 Chevy K-20
Old 07-04-2023, 03:00 AM   #1221
Braunschweiger
Re: Frankentruck
A great job and a significant improvement in comfort.
Good idea with the glove box and the vents.
Greetings Harald
My 62 build thread
Old 07-05-2023, 11:05 AM   #1222
cwcarpenter98
Re: Frankentruck
Will do, thanks! Hopefully no issues will come about from all the recent things I've done. See ya Friday or Saturday!
Thank you! Really looking forward to having A/C
Christian Carpenter
Old 07-06-2023, 10:26 PM   #1223
cwcarpenter98
Re: Frankentruck
I have some great news. The air conditioning system works great! It is so nice being able to drive around without feeling like a turkey baking in an oven.
In the whirlwind of adventure that happened yesterday, I took the truck to a local shop to have the ac evacuated and charged. The owner of the shop has a 63 as well, so that made it easier to leave it under his care.
While waiting for the truck to be done, I was able to fix the overdrive issue. Since I got the rebuilt overdrive back in, it would never shift into overdrive. Turns out, the solenoid I had on it burnt out inside. It smelled burnt when I opened it up and it would not hold properly after shooting the pawl thingy out. That was the solenoid that came off my parts transmission I had put in over a year ago. The solenoid I originally had on the transmission when I first got it in the truck just stopped working one day. I never took it apart to identify why since I had the other solenoid. Well, I finally took it apart to find that one of the contact points had broken in two. So I did what made the most sense. I took the good contact point parts from the burnt up solenoid to replace the broken ones. Once I replaced the fuse that melted from the burnt solenoid, overdrive worked great again.
At around 9pm last night, I checked to make sure the windshield washer system was working and the switch fell apart completely. It was an aftermarket switch that obviously wasn’t made to last. I ended up replacing it with another switch and knob that I had in my stash. It’s a slightly different style button, but I don’t care since it works now.
The trip up to Lebanon, TN this morning went well with no issues. Downtown Lebanon has a really neat look to it. I’m looking forward to enjoying the SETN show tomorrow and Saturday!
Christian Carpenter
Old 07-06-2023, 11:04 PM   #1224
Getter-Done
Re: Frankentruck
Here is a couple places to eat .
https://www.mrpanchosmx.com/
And What A Burger
https://locations.whataburger.com/tn...erland-st.html
84 Chevy K-20
Old 07-07-2023, 12:07 AM   #1225
Arne
Arne's Avatar
Re: Frankentruck
Good news on the A/C and overdrive! I know that same A/C system on my '64 totally rocks.
Had to laugh a bit on the windshield washer. What swank! My truck has single speed wipers with no washer. I haven't been able to find a knob for my switch, they all have the hole in the middle for the washer switch that I don't have.
- Arne
