Old 10-18-2021, 06:04 PM   #701
Jblackie47803
Re: Post those wheels gallery
Haven't mounted them yet but cheap 6 lug rallys. Guy that balanced them had to add weights to only two of them. Said the others were perfect.
Jblackie47803 is offline   Reply With Quote
Old 10-23-2021, 09:26 AM   #702
Slowguy
no tires but looks like a good test fit!
Slowguy is offline   Reply With Quote
Old 10-24-2021, 03:19 PM   #703
Greasey Harley
Greasey Harley's Avatar
I need to polish my slots
...if you know what I'm sayin'
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 10-25-2021, 07:54 PM   #704
72Teeroy
Here’s mine
72Teeroy is offline   Reply With Quote
Old 10-26-2021, 06:46 AM   #705
Six862m6
Six862m6's Avatar
My 68's wheels. Other than they are 6 lug 15"ers, I'm not sure what they are to be honest. They were on the truck when I got it (the first picture is the day I brought the truck home some 12 years ago..... man have I done some work to her since that day!). I believe they are 8" wide but they might be 10"s. The center caps say "PACER" on them.
Six862m6 is offline   Reply With Quote
Old 10-26-2021, 07:15 AM   #706
Jiggers72-GMC
Jiggers72-GMC's Avatar
That's a hefty load of wood on there man, right on !!!
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 10-26-2021, 07:20 PM   #707
glider_6969
Man it's been awhile since I've been here.. just put some new rubber on mine, old ones had no miles but a lot of age and started to shred, wasn't pretty.
Old tire,
New tires,
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline   Reply With Quote
Old 10-27-2021, 07:26 AM   #708
Jiggers72-GMC
Yes it sure needed new tires huh, I also love the paint scheme, you gave me a hell of an idea for my stepper build, thank you Glider
not to high jack this thread but what seats do you have in there ??
Old 10-27-2021, 02:16 PM   #709
71c10RDU
18” us mags
71c10RDU is offline   Reply With Quote
Old 10-28-2021, 07:20 AM   #710
Jiggers72-GMC
Very nice looking truck 71c10RDU
Old 10-29-2021, 06:56 PM   #711
glider_6969
No problem , thanks.
They are from a 2002 Silverado short box, they have the integrated seat belt. I took off the head rest.
68 Long stepper
Old 10-30-2021, 07:27 AM   #712
Jiggers72-GMC
This forum needs a LIKE button, thanks
Old 05-27-2023, 09:12 AM   #713
ghackett1
68 C10 Longbed
ghackett1's Avatar
Six lug Ralley Wheels
ghackett1 is offline   Reply With Quote
Old 05-28-2023, 08:15 AM   #714
HalfBrit
Old school Boyd’s Turbo Tech2. Purchased from Traders truck parts in CA. They were full polished, but I blasted the centers for some contrast. 17x8 with 255/50-17 tires.
HalfBrit is offline   Reply With Quote
Old 05-28-2023, 09:35 PM   #715
Mickeymotormount
Active Member
Mickeymotormount's Avatar
Here are mine. 19.5" Kelsey Hayes rims with 8R19.5 tires.
John
1967 C20 2WD Longbed
2001 2500 HD 4X4 Extended cab long bed
Mickeymotormount is offline   Reply With Quote
Old 05-28-2023, 11:55 PM   #716
allchevy58
allchevy58's Avatar
8x16 Wheel Vintiques.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 05-29-2023, 01:13 AM   #717
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
15x8 aftermarket 6 lug Corvette Rally's at all 4 corners. Tires are from Diamondback where they add the redline to a new radial. Fronts are 245/60 and the rears are 275/60
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 06-05-2023, 10:34 PM   #718
ESC
Junior Member
bought these almost 20 yrs ago, Intro 17x8 front 17x10 rear
ESC is offline   Reply With Quote
Old 06-13-2023, 07:45 AM   #719
bdoobie69
Ridler 695, 20x8.5", 4.75" backspacing on all 4 corners.
275/40/20 tires all around.
Stock 72 rear and front disc brakes.
2.5" drop spindles-2" springs up front
Drop spring in rear with a block to level it.
bdoobie69 is offline   Reply With Quote
Old 06-13-2023, 01:38 PM   #720
wrangler94
Still a work in progress, trying to restore it back basically original. Not sure yet if I want to keep these wheels or go back to factory.
1970 Chevy Custom 10
1970 truck project
wrangler94 is offline   Reply With Quote
Old 06-14-2023, 01:33 PM   #721
dennislbrooks
dennislbrooks's Avatar
on a 1959 GMC 4wd. I am pursuing somewhat damaged chevy caps for the front as I will take the middle out for the hub. I would not do that to GMC caps. 8-) but back is done on GM 4wd rallys,
Yea cap is 55-57. I have a 58/59 on the step bed fender spare. I keep looking.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 06-17-2023, 10:05 AM   #722
Extended Power
Extended Power's Avatar
My 1970 with the polished Centerlines when I bought it, the Outlaw IT'S when I swapped to 5 bolt, and a shot of the new Schott SL65 Deep Concave back wheels before narrowing the rear end.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 03-02-2024, 10:07 PM   #723
del4fun
del4fun's Avatar
2024 Wheels are needed. Got Any?
US ARMY RET, SUPPORT THE TROOPS
1972 Custom/10 Short Fleet 4.5/ 5 Drop
Dogg Pound Customs
del4fun is offline   Reply With Quote
