Old 05-29-2023, 01:38 PM   #3851
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today.The 3rd chapter
Expensive way to mask but I have three rolls that were given to me . 3M welding and spark deflection paper . Nice it has a little adhesive to hold it in place
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-30-2023, 07:05 AM   #3852
Jiggers72-GMC
Mark, it looks like your starter is too far away from the flex plate, if you have a starter shim in there, take it out ........ replace the Bendix as well .
Jiggers72-GMC is offline   Reply With Quote
Old 05-30-2023, 07:39 AM   #3853
72c20customcamper
No shim ,it’s a Powermaster had a good gab when I installed it a few years ago . Think the damage was before my ownership and it got worse over time . I should have inspected the flex plate more thoroughly.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-30-2023, 07:43 PM   #3854
guyryan100
guyryan100's Avatar
I removed the bed wood to refinish it. My bed wood planks are Birch wood. I finished them many moons ago with polyurethane, that has not held up well. I plan on stripping that off and using an oil instead of a surface coating. I also replace the sending unit because the fuel level float floated away on the last one. I used a plastic float instead of the brass one this time around.
guyryan100 is offline   Reply With Quote
Old 06-01-2023, 03:55 PM   #3855
OregonNed
OregonNed's Avatar
Gearing up for a 4/5 drop and disc brake conversion up front this month -
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 06-01-2023, 05:43 PM   #3856
ghackett1
68 C10 Longbed
ghackett1's Avatar
Installed new CCP rear sway bar on the 68.
ghackett1 is offline   Reply With Quote
Old 06-01-2023, 06:05 PM   #3857
LNP
I hooked my trailer up and helped my son move from one storage place to another
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 06-01-2023, 07:14 PM   #3858
zicc1835
zicc1835's Avatar
Originally Posted by oregonned View Post
gearing up for a 4/5 drop and disc brake conversion up front this month -
nice
zicc1835 is offline   Reply With Quote
Old 06-01-2023, 07:16 PM   #3859
zicc1835
zicc1835's Avatar
pictures......
Old 06-02-2023, 08:10 AM   #3860
ghackett1
68 C10 Longbed
ghackett1's Avatar
Originally Posted by zicc1835 View Post
pictures......
Here’s some pics of the new CCP rear sway bar installed yesterday.
Old 06-02-2023, 08:14 AM   #3861
ghackett1
68 C10 Longbed
ghackett1's Avatar
https://www.67-72chevytrucks.com/vbo...1&d=1685707942
Here’s pics of the front sway bar installed on my 68 C10 last weekend. I used an original C10 bar with CCP mounting brackets and poly bushings.
Old 06-02-2023, 08:58 AM   #3862
zicc1835
zicc1835's Avatar
Nice thanks for posting my front is done and need to do the back have what I need just haven’t got there yet but this is a motivator
Old 06-02-2023, 10:51 AM   #3863
ghackett1
68 C10 Longbed
ghackett1's Avatar
Yep, understand. Just so you know for the rear bar I installed you will need to drill (6) holes (at least for a 67-72 c10). Good luck👍
Old 06-02-2023, 11:48 AM   #3864
72c20customcamper
Rear bearings and shoes
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-02-2023, 09:08 PM   #3865
D.B
D.B's Avatar
Nice install, what diameter is the rear bar??
D.B is offline   Reply With Quote
Old 06-02-2023, 10:22 PM   #3866
MikeB
MikeB's Avatar
I installed a rear bar many years ago on a long bed truck that already had a front bar. The rear bar really made a difference in steering response and how flat the truck stays in corners. I mean, we're not talking Camaro, but it was a major improvement!
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 06-02-2023, 10:31 PM   #3867
MikeB
MikeB's Avatar
I re-installed my windshield wiper motor with a new washer pump. Kind of a PITA to get the three bolts started, but it all works great. BTW, Rock Auto had the lowest washer pump price by a large margin.
I used cowl-to-motor and shaft seals from GMC Pauls. They are first rate.
And this is a great tool for removing and re-installing the wiper arms. Lisle 65750, Dorman 49023
Mike
Old 06-03-2023, 12:14 AM   #3868
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Threw this together today, it's been a long time coming. The outer has been wall decor the last 7 years. Inner was shot, sanded, shot again and a clear coat, needless to say it's much heavier now. Took longer than I thought of course, nylon clips have to be sanded just right. Anyway, we install it tomorrow. Edit, installed. My assistant, really vise versa, he's body and paint guy dropped these off today. Tires due "in a month", bumpers due "call back in two weeks", and upholstery & flooring is supposed to call, someday. Other than that done.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-03-2023, 11:21 AM   #3869
72c20customcamper
Grill came out great .
All of the bearings and 2 of the races came today just waiting on the outer races and grease seals . At least there are no Chinese parts going on the truck . USA and Japan
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-03-2023, 11:29 AM   #3870
ghackett1
68 C10 Longbed
ghackett1's Avatar
Thanks, I notice the difference. Glad I did it. Here are the details on the bar I installed:
1963-1972 Chevrolet C10 /GMC Truck 1-1/8" Rear Sway Bar Kit CPP
Old 06-03-2023, 11:32 AM   #3871
ghackett1
68 C10 Longbed
ghackett1's Avatar
Thx Mike, yes I can feel the difference.
Old 06-03-2023, 03:13 PM   #3872
wrangler94
Nothing actually done to the truck, because it's 30 miles away at my dad's shop for now, but parts boxes are arriving New master cylinder, soft brake lines, wheel cylinders, brake parts for all the drums, new period correct carburetor has arrived, the rebuilt one that was on it was a pre 68.
Still waiting on the shipment from Cliff's High Performance for the throttle shaft bushing kit and rebuild kit to make the carb as perfect as I can make it. Pic just because
wrangler94 is offline   Reply With Quote
Old 06-03-2023, 04:45 PM   #3873
72c20customcamper
Uhh oh I wasn’t happy with the color of the passenger fender and the cowl , I didn’t understand why it was darker than the rest of the truck . When I painted the ammo box a few weeks ago I figured out why . I inadvertently had grabbed the wrong paint I used the 68 Golden anniversary paint . Both cans were open and I just saw gold on the outside . Was a stupid mistake .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-03-2023, 05:46 PM   #3874
D.B
D.B's Avatar
Thanks, I installed one back in the mid-90's on my 72 C20 that was 7/8" diameter. I been wanting to go to this larger bar. Looks like I will be talking to CPP for sure.
Old 06-03-2023, 09:59 PM   #3875
MikeB
MikeB's Avatar
Probably my all-time favorite truck color!
My dad had a gold 67 Impala 2dr hardtop with gold vinyl interior. Probably a different gold, but it was super cool!
Mike
