Old 06-05-2023, 10:34 AM   #1
KyleSeal
KyleSeal's Avatar
Need Some Info with this Drop
So currently on my 67 I am running a 5.5 front and 7 rear drop. This is achieved with 5 inch drop springs and 2 inch blocks in the rear, 3 inch springs and 2.5 inch CPP disc brake spindles in the front. I am using the CPP tubular control arms in the front as well, stock crossmember.
How have yall gotten around the inner fender issue? I have stock replacement inner fenders, but man its close, which I knew would be close but not this close. I assume I will need to section the inner fenders and move them up. I also assume I would need to move the battery, is that true?
Can I get some pictures of how everyone is going about doing this? Id rather not buy a set of aftermarkets since Ive already got some factory style ones.
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 06-06-2023, 08:48 AM   #2
SCOTI
SCOTI's Avatar
Re: Need Some Info with this Drop
Interference will/can be dependent on the front tire OD. What size wheel/tire combo are you running?
Common solutions are no fender wells, sectioned & raised stock stuff, or aftermarket fabricated pieces.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-06-2023, 01:36 PM   #3
KyleSeal
KyleSeal's Avatar
Currently there are 235/75/15s, stock 4 nub wheels. These tires are some off a truck that came into my work and needed new tires (rubbed terribly) so I threw them on my truck as rollers until the truck is on the road again. So Im not stuck to this size, although it is a nice looking size.
Toano VA
Old 06-06-2023, 01:45 PM   #4
SCOTI
SCOTI's Avatar
Those 28.8" front tires are part of the issue on 'what fits'. No taller than 28" up front helps.
If I were a betting man, I'd bet the most common front tire height ranges from 27-28" max. 27" would likely clear stock wells & anything taller is where mods or the aftermarket stuff comes into play. A 215/75 or 225/70 15" tire puts you around 27.4-27.5" front tire height.
Some guys run short (<27" up front) tires & have no clearance issues, but the combo doesn't look right to me as I like the wheel opening filled vs a large gap/space.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-10-2023, 01:19 PM   #5
PowerdbyChevy79
PowerdbyChevy79's Avatar
With that drop you should stay 27" and under.. a 255/60 is around 27.. and it minimizes wheel gap.. just depends on the wheel type and look that your going for..
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
custom, drop, inner fenders, modification
