Old 06-06-2023, 07:24 AM   #1
K10-Kansas
K10-Kansas's Avatar
Is this the hole for the parking brake
Hi. There was no parking brake on my truck when I bought it. Supposedly it's a 77-78 K10 chassis. I bought a C10 cable from LMC since that's the one that fits my C10 pedal assembly. But maybe it doesn't fit my K10 frame. Is this hole on the frame where this part of the cable is suppose to set in? Also, it seems weird that the parking brake would set outside the frame instead of inside.
1971 C10 body. 76 4x4 chassis cut to short frame. Crate 350 2nd Gen small block. 4BBL Holley 4160. 4L60 transmission. ~ James
K10-Kansas is offline   Reply With Quote
Old 06-06-2023, 07:32 AM   #2
K10-Kansas
K10-Kansas's Avatar
Re: Is this the hole for the parking brake
Other pic
Old 06-06-2023, 06:53 PM   #3
kwmech
The C10 cables may come up short as the 4wd chassis sit higher. AND you're right they should be on the inside of the frame, 'cept for the one coming from the parking brake mechanism
Old 06-06-2023, 08:48 PM   #4
mongocanfly
mongocanfly's Avatar
what you need is a couple of short lines that can be bent back up into the reservoir ,, put the master cyl in a vice or such and start pumping on the piston
lots of utube on this if you cant figure it out
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-07-2023, 07:06 AM   #5
K10-Kansas
K10-Kansas's Avatar
Hey Mongo, I deleted that post since I had intended it to be in the other thread.
