01-29-2019, 05:07 PM | #26 |
Re: Turn Signal Switch Question
If you have not done so all ready, check the connections at the head lamp bulbs themselves and check the connections at the dimmer switch. That is what I would start with.
I will look at some wire diagrams I have and see what else I can think of that could be wrong. Over a year ago I had a problem on my truck with the wires going to the dimmer switch getting hot I think it was a bad factory wire crimp job or something I cant remember right now. I will have to think about it.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
01-29-2019, 07:01 PM | #27 |
I haven't checked the connection to the headlights themselves yet but I did install a new dimmer switch i originally thought that was the problem but that didnt help. Could it be a loose ground somewhere maybe
01-29-2019, 08:17 PM | #28 |
Just went out checked a few more things on the truck and noticed when I have my headlights on I dont have a right turn signal but I have a left. With headlights off I have both
01-30-2019, 04:30 PM | #29 |
Last night I looked at the wire diagrams and am 99.9% positive that the headlights have nothing to do with the turn signal switch.
It's starting to sound to me like some one has messed with the wiring and spliced something where they shouldn't have I would start checking all the headlight wiring from under the hood and under the dash. Look for any extra wires that don't look original or any extra splices. It would be best to have a wire diagram but it can be done with out one. If you don't have a wire diagram you might find one online or I can post one here on the forum. And yes check all your grounds. I'm leaning towards there being funny wiring because the turn signal switch thing just seems "fishy" to me.
01-30-2019, 04:35 PM | #30 |
Moderator
FAQ Section - http://67-72chevytrucks.com/vboard/s...d.php?t=646002
Electrical Threads: 60-66 Wiring diagrams from Hilandr451 http://www.6066chevytrucks.com/id64.html 60-66 Chevy - GMC wiring basics 60-66 full body wiring : December 2009 / Electrical forum 62' chevy c10 wiring diagram needed : May 2014 see thread, PM one of the members there for a diagram Wiring Diagram - Lights Only : May 2014 1960-1966 GMC headlight adjuster kit : July 2014 options for parts to use, if you cannot find original bits Turn Signal Switch Question : June 2014
01-30-2019, 04:39 PM | #31 |
Ok I'll start checking out my wires and ground and see what I can find hopefully it will be something obvious I'm new to all this and definitely a novice at wiring lol. Thanks for all the help it's much appreciated
01-30-2019, 05:23 PM | #32 |
Checked the front right turn signal it was dimmer than the left so I twisted it in the housing and it got brighter so that was a ground issue for that one and it works with headlights on. Now I still dont have rear turn signals with lights on I'm assuming it's a ground issue also. Where are the headlight grounds located. Making a little progress I guess lol
01-30-2019, 10:00 PM | #33 |
Cleaned up the screws and housing on my rear lights and now I have front and rear turn signals with my lights on. My front right parking light is not getting a ground any suggestions on how to get it to ground better when I shut my hood sometimes it goes completely out. Could these issues I've found be the problem behind my headlights randomly turning off and on?
02-01-2019, 04:26 PM | #34 |
For your marker light on the hood the first thing I would do is check if the light housing is tight on the hood. Try to loosen and retighten the mounting screws or possibly remove the housing and cleanup the metal where it contacts the hood.
WARNING! The screws may be rusty and break when you try turning them! (This happened to me) If this does happen you can re drill new holes for screws or just use self taping sheet metal screws. (that is what I did) A 2nd thing to look at is that you may need to connect a ground strap from the body of the truck to the hood or directly to the light housing if need be. This more than likely is not the case however if you said the other light works fine but it may be something to try. You said that you have front and rear turn signals with your lights on. Unless I have miss understood you, that means that you do not have turn signals with your lights off? If that is the case than I go back to my earlier statement that I think you have some wiring under the dash that is messed up because the turn signals should work at any time the ignition switch is turned on regardless whether the head lights are on or off. I hope I have helped you a little bit. Maybe someone else will chime in that has some better input.
02-01-2019, 09:45 PM | #35 |
Got my marker light fixed it was the housing that was loose. Appreciate the help. Now my next problem is my headlights I took a drive this evening and noticed the lights only randomly go off when I use my brights on dim they wont go out what could be causing this could it be in the headlight switch?
02-01-2019, 10:16 PM | #36 |
There is a possibility that it's the headlight switch.
I would replace it and see what happens.(I should have mentioned it before LOL) Sometimes the internal safety breaker goes bad or does not work right. sometimes you can fix them but It may be best just to replace the whole switch. Even if you replace the switch and it does not fix the problem at least you will have one less part of the system to diagnose. LOL
02-01-2019, 10:53 PM | #37 |
Hopefully it's just the switch that's bad these electrical problems are driving me nuts lol. I'm gonna try and replace it tomorrow sometime. I'll let you know how it goes hopefully good. Thanks for the help
02-02-2019, 10:21 PM | #38 |
Well the headlight switch wasn't the problem they are still flickering when I have them on bright but not on dim. Not sure if the pic is gonna go through but what is this and could this be causing my problem I noticed the wiring for the headlights goes through this
02-03-2019, 10:30 PM | #39 |
Looks to be some kind of relay or something.
I have never seen one of these on these trucks before for the head lights. It could be something aftermarket. Anybody else seen this?
02-05-2019, 03:05 PM | #40 |
So after thinking about it for a while I'm pretty sure its a relay of some kind.
I've just never seen one in these trucks before. It could be your problem but I don't Know for sure. Have you checked the connections on it?
02-06-2019, 08:06 PM | #41 |
Yeah I checked it out i think it is the horn relay i unplugged it and it had no effect on the lights at all. I did unplug my headlights and took the metal clip out of the plug and it and the wires connected to it were corroded i cleaned the clip up but the wires were still corroded could the corrosion on the connection from wire to the metal clip be the problem
02-07-2019, 02:00 PM | #42 |
If its corroded really bad it could be the problem.
06-08-2023, 07:29 AM | #43 |
Anyone know what the screw size is that attaches the turn signal arm to the actual switch? I either lost it, or neither my new arm nor switch came with one...
