Old 06-08-2023, 10:06 AM   #3901
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today.The 3rd chapter
Think I caused the failure of the ujoint. The only bad ones were where the u bolts hold it onto the pinion . I must have been over zealous in tightening them down . And I highly recommend the Tiger tool for u joint removal makes it super easy I don’t even use the 20 ton press any longer.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-08-2023, 10:15 AM   #3902
americanmusc1e
americanmusc1e's Avatar
Got the 72 back together and was doing a check on the drivetrain and found a bad ujoint at the pinion. I had checked the ujoints for slop but I got no movement but visually you could see they were shot , I had changed them all 4 years ago when I did the carrier bearing with inexpensive ones from autozone won’t be doing that again , when I the shaft off the ujoint just fell apart . Guess I found the vibration . Going to do all four
replace them with Spicer or Moog if you can get them. Cheap u-joints are bleh
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 06-08-2023, 10:17 AM   #3903
americanmusc1e
that looks handy! The hardest part with a press is supporting the rest of the driveshaft level while you are lining everything up.
-- Josh
Old 06-08-2023, 01:34 PM   #3904
72c20customcamper
Used Moog 232 .says they are super strength whatever that means . Picked them up at Napa
Super easy . Another must have tool I bought it to remove the u joints on the front axles on my Dodge . Even though it said it was for that application it seemed a little too small . It still worked but the next size up would have worked better they make three sizes . This is the medium one
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-08-2023, 07:36 PM   #3905
americanmusc1e
Some of the "super" u-joints don't have a grease zerk and are not cross drilled for grease channels. This is supposed to aid in strength. That probably matters more for the hardcore offroaders. I just generally try to buy spicer or moog because the seals and grease used seem to be higher quality than the cheaper parts store ones.
-- Josh
Old 06-08-2023, 07:44 PM   #3906
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Got mine back on the road after been down for 20 months, I know not a long time in the rebuild scheme of things, so was out cruising the last 2 days.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-08-2023, 08:12 PM   #3907
72c20customcamper
It’s crossed drilled and has a zerk but it’s on a cap not the body
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-09-2023, 01:21 PM   #3908
cornerstone
cornerstone's Avatar
Congratulations! She's a real beauty.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-09-2023, 07:45 PM   #3909
72c20customcamper
Put the driveshaft back in the 72 . Drives like a new truck nice and smooth . Then I put the front bumper back on the 68 what biatch of a job . No matter how much monkeying around with it it’s still not to my liking . I think it’s a little twisted as I get one side in and the other upper bracket didn’t line up . It’s an aftermarket so I would doubt the twist
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-09-2023, 08:48 PM   #3910
Old_Gold
Old_Gold's Avatar
I'm getting ready to put a much healthier engine back in the 72!
Old_Gold is offline   Reply With Quote
Old 06-09-2023, 09:27 PM   #3911
69Penka
I just wanted to change out my idiot light gauges with a cluster that had guages and I wound up here!
69Penka is offline   Reply With Quote
Old 06-09-2023, 09:32 PM   #3912
69Penka
Finished putting her back together today complete with in bed spare tire carrier, tach, dome light with door switches, front side marker lights that work, and windshield washer pump!
Old 06-09-2023, 09:37 PM   #3913
69Penka
More. 😁
Old 06-09-2023, 11:29 PM   #3914
zicc1835
zicc1835's Avatar
Originally Posted by 69Penka View Post
More. 😁
wow
zicc1835 is offline   Reply With Quote
Old 06-10-2023, 08:05 AM   #3915
Jiggers72-GMC
Jiggers72-GMC's Avatar
Well done Penka, what a nice change.
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 06-10-2023, 02:18 PM   #3916
HalfBrit
Started laying out the possible wiring paths for the AAW, FI and air ride harnesses on my ‘70.
HalfBrit is offline   Reply With Quote
Old 06-10-2023, 03:21 PM   #3917
72c20customcamper
Won a trophy asked that it not be judged by t they gave me one anyway . About 75 cars and it’s a top 40 trophy so step above a participation trophy
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-10-2023, 06:41 PM   #3918
ghackett1
68 C10 Longbed
ghackett1's Avatar
Did my first oil change after 500 mile break in! Big step. So far so good on the Blueprint 355/390hp!
ghackett1 is offline   Reply With Quote
Old 06-10-2023, 07:13 PM   #3919
'68OrangeSunshine
'68OrangeSunshine's Avatar
More. 😁
I like how you Two-Toned the interior. Not Factory, I don't think, but it sure looks cool.
Old 06-10-2023, 07:49 PM   #3920
zicc1835
zicc1835's Avatar
nothing to my truck today ...but I went to a local car show and saw this 69 owner did the LS swap nice truck ...oh and I took my 48 Pontiac and took Peoples choice award
Old 06-10-2023, 11:04 PM   #3921
Sheepdip
Sheepdip's Avatar
Nice!!...Pretty Slick Old Tin Indian!
Sheepdip is offline   Reply With Quote
Old 06-10-2023, 11:13 PM   #3922
'68OrangeSunshine
Do the old Poncho's spotlights work?
Old 06-11-2023, 02:33 AM   #3923
Rust_never_sleeps
Rust_never_sleeps's Avatar
Replaced some scrungy rear wheel cylinders, but still failed to bleed the back system.
Rust_never_sleeps is offline   Reply With Quote
Old 06-11-2023, 07:43 AM   #3924
zicc1835
zicc1835's Avatar
Yes sir:
Old 06-11-2023, 07:51 AM   #3925
zicc1835
zicc1835's Avatar
thank you !
