Old 06-11-2023, 09:38 AM   #3926
ghackett1
68 C10 Longbed
ghackett1's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by zicc1835 View Post
nothing to my truck today ...but I went to a local car show and saw this 69 owner did the LS swap nice truck ...oh and I took my 48 Pontiac and took Peoples choice award
Looks like a great car show! Thx for pics!
ghackett1 is offline   Reply With Quote
Old 06-11-2023, 06:40 PM   #3927
'68OrangeSunshine
'68OrangeSunshine's Avatar
Yes sir:
Cool.
Old 06-12-2023, 01:46 PM   #3928
OregonNed
OregonNed's Avatar
Over the weekend I painted my new brake calipers to be ready prior to my brake conversion. Used high heat primer, followed by VHT high temp black and clear coat.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 06-13-2023, 04:02 AM   #3929
Rust_never_sleeps
Rust_never_sleeps's Avatar
Popped the rear lines off the combo valve and blew air through them to verify there were not obstructions.
RR finally bled out fine with low vacuum. LR still seems to have something constricting or perhaps leaking air
Will confirm both in the cold light of day
Rust_never_sleeps is offline   Reply With Quote
Old 06-14-2023, 06:55 PM   #3930
Casper42
Casper42's Avatar
slapped my truck onto my chest - so far, much better fuel economy
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 06-14-2023, 07:24 PM   #3931
72c20customcamper
72c20customcamper's Avatar
Cool shirt .
Towed the trailer over to my moms . It will be on the trailer tomorrow behind the motorhome . Should be in Macungie in the afternoon
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-15-2023, 07:03 AM   #3932
Jiggers72-GMC
Jiggers72-GMC's Avatar
Nice T shirt Casper, very nice
have a safe trip yo PA Mark, lookin' good
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 06-15-2023, 12:35 PM   #3933
samkost
samkost's Avatar
After chasing and correcting a couple of wiring/fuse box gremlins, I dropped the steering column (hopefully for the last time ) and replaced the 50 year old tachometer.
samkost is offline   Reply With Quote
Old 06-15-2023, 07:28 PM   #3934
'68OrangeSunshine
How robust are those OEM tachs?
Will a reversed polarity burn them out?
[Asking for a friend.]
Old 06-15-2023, 08:26 PM   #3935
Casper42
Casper42's Avatar
why'd you need to drop the column? I got my cluster out "fairly" easily without - just a little finesse and wiggling. were you in attendance at Enumclaw the other week?
Old 06-16-2023, 03:29 AM   #3936
pjmoreland
pjmoreland's Avatar
Finally got around to stripping and painting these pulleys I got from Classic Bowties over a year ago in preparation for installing a Gen 5 Vintage Air system in a few weeks.
pjmoreland is offline   Reply With Quote
Old 06-16-2023, 10:17 AM   #3937
samkost
samkost's Avatar
I replaced it with an aftermarket tach.
I’m unfamiliar with the reverse polarity you mention.
Old 06-16-2023, 10:34 AM   #3938
samkost
samkost's Avatar
Just being careful.
Fresh paint mainly.
Oil gauge line, speedometer cable, dash harness clip and big clumsy hands for easier access.
I missed the Enumclaw show.
Old 06-16-2023, 02:25 PM   #3939
72c20customcamper
Found a nice period correct Coleman cooler at a reasonable price
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-16-2023, 06:14 PM   #3940
Casper42
Casper42's Avatar
Installed Retrobright LED headlights, in Classic White. Far better visibility, and they look pretty close'ish to OEM. Classic Industries ran a 20% discount last weekend, so that really helped on this somewhat pricey purchase.
Old 06-17-2023, 06:53 PM   #3941
67C10Step
67C10Step's Avatar
Wife and I took the truck on its furthest journey since putting it back on the road. Went to the annual car show and swap meet on Petit Jean mountain in Morrilton, AR. About 80 miles one way and the truck did fine. Did get me to thinking about vintage air though!
Picked up a pair of Chevrolet script valve covers for my little mouse motor. Gonna try to get those cleaned up and painted before the C10 shin dig in July in north AR.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-17-2023, 08:52 PM   #3942
Sheepdip
Sheepdip's Avatar
My GV Overdrive went on the blink a couple weeks ago and finally had time to trouble shoot it. I started with the easily accessible stuff and thankfully found it right away.
The button/switch on the manual gear shift has two bullet connectors GV supplied that feed into a little snap in telephone style connection adapter pigtail just before the controller, about 4" or so long. It grounds the milli-volt relay that powers the 12 volt solenoid to engage the OD.
I unplugged that phone connector from the controller and hit it with Electric Clean, plugged it back in...no dice.
Next I unplugged the two bullet connectors at the other end of the pigtail and hit them with Electric Clean, they tested with good continuity with the ohm meter so I knew the button was good, re-connected and... Bingo!
Dirty/bad connection at the bullets was the problem. I was a happy camper!
Sheepdip is offline   Reply With Quote
Old 06-20-2023, 01:50 PM   #3943
Rust_never_sleeps
Got the rear drums pressure bled, after failing multiple times to do so with vacuum(yes the shuttle valve was pinned). Had to finish building the Motive bleeder due to missing o-ring and their goofy clamping system, but it works really well once it seals.
Old 06-20-2023, 06:57 PM   #3944
indymachinist
Charged the A/C. Rode home with the windows closed in comfort. Oh yeah!
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 06-20-2023, 07:52 PM   #3945
Steeveedee
Who Changed This?
Steeveedee's Avatar
Brought some glued-up wood for shelving home. Made a freeway run to warm up the bodily fluids while I was at it. Surging at idle. Probably needs a new needle and seat, again. Cliff Ruggle's kit lasted a few years. I got lazy and bought local, didn't get the ethanol-proof needle.
~Steven
Simi Valley, CA
Old 06-21-2023, 04:16 AM   #3946
pjmoreland
pjmoreland's Avatar
Stripped and painted these original side mirrors
Old 06-21-2023, 10:06 AM   #3947
72c20customcamper
Have I said before I hate doing hoods . Four coats of filler primer dusted with guide coat , initial sand with 150 paper . Going up to 220 - 320- final is 400 since it’s a single stage paint
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-21-2023, 05:40 PM   #3948
67C10Step
67C10Step's Avatar
72c20,
How do you like the Durablocks for sanding? Saw some in different lengths at the swap meet last weekend and considered them since I am about to really get into the bodywork on my jeep project.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 06-21-2023, 07:55 PM   #3949
72c20customcamper
Originally Posted by 67C10Step View Post
72c20,
There are very good . I bought the big set at the Carlisle truck show two years ago prices are all over the place for the same set guess it depends on the seller . I did have a couple of them that I had bought years ago but never the whole set
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-23-2023, 01:30 PM   #3950
pjmoreland
pjmoreland's Avatar
Installed some original mirror heads after painting them black. Painted this crusty lug wrench while I was at it.
