#51 |
![]() Join Date: Nov 2022
Re: brakes go to floor
That small reservoir is the back brakes so I assume my old brake tubing that I cut and was using for this test wasn't getting a good seal.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James |
#52 |
That’s what’s nice about those kits, they seal and are easy to use.
#53 |
I pulled the proportioning valve brake light grounding connection to stabilize the internal slide while bleeding the back brakes and have a question. Is the o-ring supposed to be midway on the threads like that?
#54 |
No, but when you put it back in the o ring will roll back up.
Or just roll it up by hand. |
#55 | |
#56 |
I replaced the master cylinder brake lines because I felt that they weren't getting a good seal. They were 51 years old. Bench testing the master cylinder shows it working well. I adjusted the back drums and they are so far out now that it is really tough to get the drums on and off. I put the bleeder bolt in the proportioning valve. Bled all of the lines again. I added fluid to the master cylinder everytime it got down halfway. That happened about 5 times. And the brakes still go to the floor. I can build up a little bit of pressure if I pump the brakes several times but even doing that, it doesn't stop the wheels from spinning. I've got it up on stands with the tires off.
Any suggestions?
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James Last edited by K10-Kansas; 06-11-2023 at 09:19 AM. Reason: Typo |
#57 |
It sounds to me like this master cylinder is either defective or damaged. I guess they can be damaged by having the pedal go to the floor too many times. It has never happened to me though. I would try another one and hope for the best.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#58 |
![]() ![]() Join Date: May 2015
Can you get some pics of all the brake components on the truck? Maybe somebody can spot something
I know a guy that has a scout that had similar issues...he had his front calipers on backwards.....it wasn't until he shared pics that it was spotted
#59 | |
How would having calipers on backwards cause the brake pedal to sink to the floor?
#60 | |
The bleeder has to be on top. If they're on the wrong side the bleeder will be on the bottom and you won't be able to get all the air out.
#61 |
I want to preface what I'm about to say, with an face-saving explanation.
![]() ![]() After reading Mongo's post I checked mine and sure enough, while one caliper for some crazy reason does in fact have an R on it, it also has an L. The other has an L only. I had the bleeders on bottom. I reversed them, bled the brakes and it's working perfect! Thanks a ton Mongo! ![]()
#62 |
Sweet!!!!!!!!!
#63 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#64 | |
The brakes did seem to work well coming off the trailer and then didn't work well up on stands. The only reason I can guess why is that i had the pedal pushrod and clevis adjusted too short. But who knows because then I immediately blew a brake line.
