Old 06-14-2023, 10:19 PM   #1101
knuckle-nurse
Re: 67 GMC super custom build
Super attention to detail....do you lay awake at night thinking about these mods?
72 Cheyenne C20 BB, air
70 Suburban 20 BB, air, buckets
68 CST C20 air, buddy buckets
72 Jimmy 2wd
72 Blazer 4wd air 4 speed
knuckle-nurse is offline   Reply With Quote
Old 06-14-2023, 11:17 PM   #1102
chewychevy67
Ha yeah sometimes but more ot of excitement. Some of these thing I'll think about for weeks before I pull the trigger. The worst is when you do something with nos parts that aren't readily available and I mess up. That hurts.
chewychevy67 is offline   Reply With Quote
Old 06-24-2023, 01:08 AM   #1103
chewychevy67
I got a few parts in the mail this week so I did some stuff on the truck tonight. I added a 1964 pontiac throttle dash pot to the 4gc carb with a micro switch that originally was used for switch pitch transmissions. It will be used to ground the solenoid for the cowl intake every time the throttle is closed and close the intake door. It will only open again once the throttle is opened. That way on long idles it hopefully won't bring a fuel smell into the cab. Also I had to put anew vacuumpod on the a/c idle up. I also adjusted the dash pot so even when the a/c is on and the truck is idling higher the fresh air door will still be in the closed position til the throttle is pushed down.
Old 07-26-2023, 08:21 PM   #1104
chewychevy67
I got the decals all really close to the correct color on the transmission temperature gauge project. This is now complete. It turned out really nice. Thank you ironcainine for you help on this. It would not look this correct without your help. I really appreciate it.
Old 07-26-2023, 08:54 PM   #1105
IronCanine
I'm trying....
IronCanine's Avatar
I am glad it turned out. So happy to be the smallest part of an amazing build. I'm pretty sure I'm well on the record about how cool I think this truck is. Thanks for sharing the fun!
IronCanine is offline   Reply With Quote
Old 07-26-2023, 10:00 PM   #1106
chewychevy67
So I put my in cab fuel tank in for fitment and after the new floor and taking the roof apart the neck was no longer in the center. Close but not perfect. How much tolerance does the gasket give you? Also the new floor was far from perfect on the passenger side. Driver was perfect. The bottom holes lined up but there was a 1/4 inch gap between them and the tank and the tank does not flex that much. Spacers I guess will need to be used on the 2 rear bottom bolts.
Old 07-26-2023, 10:56 PM   #1107
IronCanine
I'm trying....
IronCanine's Avatar
Once the tank is bolted in, you can put a pipe in the neck (largest diameter that you have that'll fit) and using it as a lever you can tweak the neck position to center it.
Old 07-26-2023, 10:59 PM   #1108
chewychevy67
Yeah that would work. I should probably do that when I'm doing final install after paint.
Old 07-29-2023, 12:05 AM   #1109
chewychevy67
So I changed up my illuminated entry wiring today. My interior lighting will come on as factory when the door is open and when the headlight switch is on. I made it so when you push the outside door button only the door lock lights will come on for 35 seconds. That just incase your door is locked in the dark you can see the hole. Now I also added a small light to the ignition switch so it will come on for 35 seconds as well so when you get in and you close the door and it's dark you can still see where the ignition switch is. With the sentinel headlight kit as soon as you turn the key and the sensor sees that its dark all your dash lights come on automatic . I have another timer I may use on the interior lights but the reason I seperated them from the lock lights is I don't want the lock lights to come on when yhe interior lights are on when I turn them on from the headlight switch.
Old 07-29-2023, 08:48 PM   #1110
clay68c10
clay68c10's Avatar
That is slick!
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-31-2023, 06:17 PM   #1111
chewychevy67
I also took the fiber optic light that was for the ash tray and converted it to a mini bulb. Much better lighting. There will be no more fiber optics in my truck anymore. I ordered another set of clear bulbs as I like those much better than colored bulbs.
Old 08-01-2023, 08:51 AM   #1112
zicc1835
zicc1835's Avatar
neat .....
zicc1835 is offline   Reply With Quote
Old 08-02-2023, 09:42 PM   #1113
chewychevy67
So I hooked this light up to my dash lights but I did not like how this was always on when the dash lights were on. So I had recently taken a cruise control unit apart and it had a flexible brass tab on it with a contact point on it which worked perfectly for this application. I used a piece of plastic to seperate conductivityfrom it and the ash tray and riveted a wire connector to it (so the ash tray can still be removed) and the point on the brass . This way it can ground and slide across the top of the housing . Then I put a thick clear vinyl decal on the back end of the upper inner housing so the ground contact will slide over it when the ash tray is closed and the ground will not touch. The light will only come on when the ash tray is slid out an inch or more and shut off when closed. Just like the glove box door will work.
Old 08-03-2023, 12:56 AM   #1114
chewychevy67
And maby not so fast on the fiber optics. I forgot I have this very uncommon 1973-74 chevy washer wiper plaquard that lights up. I thought this piece was very cool and bought it. I would like to see if I can get this 3d printed to use as my ignition plaquard. It would light up just like the keyhole. This one might be far fetched but I'll see where I may be able to get this done. Not sure what else I would use this for.
Old 08-03-2023, 06:25 PM   #1115
chewychevy67
Well I took the piece to a local 3D print shop and they said they can do it so well see when it returns. But today is a very important day. I am no longer imprisoned to sms auto fabrics. I got my final pieces from them. I really hated how long I had to wait for some of these pieces and the service was hard to go thru but wow their work is top notch. All the custom stuff I wanted they nailed 100%. I got the door anel inserts today. Feels so good for that to come to a close. Now all I really have left is body and paint. Then assembly. But this dream still feels years away. I sent these to SMS in September of 2018 and I only got them today.
Old 08-03-2023, 09:47 PM   #1116
clay68c10
clay68c10's Avatar
Those look sharp! Nice job.
13 Tahoe LTZ
Old 08-14-2023, 05:42 PM   #1117
chewychevy67
So they 3d printed me a piece on colored plastic. Now they are going to mold me one in clear plastic so the light can shine thru it. A few tweaks to this are going to be made but it's close. Font is perfect. 67 didn't have accessory like the 68 up did so I made this one without.
Old 08-14-2023, 06:28 PM   #1118
Getter-Done
Getter-Done's Avatar
That is Spot On
84 Chevy K-20
Old 08-15-2023, 05:35 AM   #1119
72 tigger
72 tigger's Avatar
Nice work as usual!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 08-18-2023, 10:42 PM   #1120
chewychevy67
So I went hunting for things gm did in the 70s with fiber optics and I found this piece. It has a bulb in it and you can hook 5 different optic lines up to it from a 1976 Oldsmobile. So I have decided to use the optic for both the lens and the keyhole. It's actually very bright with a led. So now I just have to wait for the clear printed piece with the lettering and see how it looks after that. If it's all good I'll modify the dash for the part.
Old 08-30-2023, 05:51 PM   #1121
chewychevy67
So I got the final drafts of the pieces I'm getting made. I am getting a plaquard for the fog lights made as well. It will be black and go where the choke goes oon the gauge bezel
Old 08-30-2023, 07:45 PM   #1122
Kronald_70GMC
Kronald_70GMC's Avatar
Those are pretty neat!
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 08-31-2023, 04:26 PM   #1123
68 C10 Driver
Here is the finished product. first one with the caprice emblem and 2 with the GMC emblem. I didn't get the button 100% centered in the ring but close. I am not sure if i am going to try it one more time or just be happy with this one. guess ill see. Now i just have to get the plastic wheel repaired.
Great choice in steering wheel! I like the styling of the car steering wheels of the 60s so much more than the trucks. Granted they were just trucks, used on farms and ranches so they didn't need to be fancy or stylish.
I used a 65 El Camino steering wheel in my truck...it just looks so much better in my opinion.
68 C10 Driver is offline   Reply With Quote
Old 08-31-2023, 04:32 PM   #1124
67 Burb
67 Burb's Avatar
That steering wheel is beautiful. Waaay nicer than what was put into the trucks.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 08-31-2023, 09:50 PM   #1125
chewychevy67
So I had removed the extra temp light in the past and added a tow script but I scrapped that idea and added the overdrive script to it so now I will know when my overdrive is engaged or not when it lights up.
