Old 06-23-2023, 04:37 PM   #3951
68bowtie
68bowtie's Avatar
Re: What did you do to your truck today.The 3rd chapter
Love that black on orange look. Nice job on the updates.
Old 06-23-2023, 04:39 PM   #3952
'68OrangeSunshine
'68OrangeSunshine's Avatar
Matching Racoon Ears, cool.
Old 06-23-2023, 04:41 PM   #3953
pjmoreland
pjmoreland's Avatar
Thanks!
I was waiting for you to say something along those lines
pjmoreland is offline   Reply With Quote
Old 06-23-2023, 04:56 PM   #3954
'68OrangeSunshine
Originally Posted by pjmoreland View Post
Thanks!
I'm sorry. Raccoon.
Old 06-23-2023, 05:00 PM   #3955
pjmoreland
pjmoreland's Avatar
I'm sorry. Raccoon.
If the PO hadn't painted the windshield and door window frames black, then I definitely would have gone with white on the grille and mirrors. I almost had the body shop repaint the frames orange when I was having the PO's body damage to the driver side front fender, door and bed fender repaired, but it was gonna cost more than I was willing to spend.
Old 06-23-2023, 05:14 PM   #3956
'68OrangeSunshine
We love Rascal.
Old 06-24-2023, 10:48 AM   #3957
Extended Power
Extended Power's Avatar
Got my rear end back from the shop that narrowed it.
Ordered new axles, bearings, and retaining plates from Moser.
Started installing the Vintage Air.
Pulled the instrument panel, to gain access to the fuel injection wiring, so I could remove it.
Welded the brake push rod to the CPP hydroboost rod.
Brainstorming how the heck I’m gonna fit two 16” fans in front of the A/C now...
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 06-24-2023, 11:14 AM   #3958
Extended Power
G.
Old 06-25-2023, 01:42 PM   #3959
72c20customcamper
72c20customcamper's Avatar
Made a proper homemade spray booth worked out well was going to buy a blow up booth on Amazon but for one hood wasn’t worth the expense . Still might when I do my next project. Came out nice for a heavy metallic single stage paint . I used an old truck of adding clear to the cup on the last two coats
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-25-2023, 05:08 PM   #3960
paul blair
Paint is looking good Mark. You are multi talented. I enjoy your post here and learn some too...........
paul blair is offline   Reply With Quote
Old 06-25-2023, 05:39 PM   #3961
68bowtie
68bowtie's Avatar
Wow that looks perfect
Old 06-25-2023, 06:46 PM   #3962
72c20customcamper
Thanks glad it helps . When I worked in my uncles body shop you would be assigned a car and was responsible from start to finish . This way you couldn’t blame anyone else for screw up .
It’s not perfect have a spot of metallic mottling and a little dust in the paint . I think it came off of me walking past the fan I believe I can nib it with 3000 or 5000 paper and polish it won’t be perfect but very acceptable . Next time I’ll get a tyvek suit
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-25-2023, 09:13 PM   #3963
samkost
samkost's Avatar
I have a truck cover ordered, so I pulled it out of the garage to dust it off and detail it.
Took it for a (no current license tabs) spin around the neighborhood.
Gonna have to chase down a rattle and a squeak inside the cab.
It was a beautiful day here in the PNW.
samkost is offline   Reply With Quote
Old 06-26-2023, 04:02 AM   #3964
'68OrangeSunshine
Mark, Is the fan sucking vapors out of the tent or getting filtered fresh air in?
Old 06-26-2023, 07:39 AM   #3965
72c20customcamper
It’s a positive ventilation system . It’s pushing filtered air into the booth . I would have used the explosion proof exhaust fan I have to exhaust the overspray but it’s to big would have pulled in the walls . The mist and exhaust went out from the other side . I’m sure a lot went out in the gaps around the top and side walls .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-26-2023, 07:49 AM   #3966
Danyo492
Performed surgery this weekend on the 67.
Danyo492 is offline   Reply With Quote
Old 06-26-2023, 05:10 PM   #3967
'68OrangeSunshine
It’s a positive ventilation system . It’s pushing filtered air into the booth . I would have used the explosion proof exhaust fan I have to exhaust the overspray but it’s to big would have pulled in the walls . The mist and exhaust went out from the other side . I’m sure a lot went out in the gabs around the top and side walls .
Amazing. Levels above Shadetree operations.
Old 06-26-2023, 05:23 PM   #3968
72c20customcamper
Dont have the luxury of a real spray booth since my uncle's shop was sold . He had a beautiful downdraft unit .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-26-2023, 11:06 PM   #3969
mr.mud1
mr.mud1's Avatar
not very glamourous but had to be done.i screwed up last year when i ordered 4 new 9.5x16.5 Firestone Transforce 10 ply tires.i forgot about the spare so i ordered another new tire,painted up the wheel and the spare tire carrier and put it all back under the truck like it's supposed to be(don't know why cause i don't have the jack but easier to find a jack on the road than a 16.5 tire)that'll do til i dream up something else to do?
mr.mud1 is offline   Reply With Quote
Old 06-27-2023, 09:00 AM   #3970
67C10Step
67C10Step's Avatar
I picked up a pair of Chevrolet script valve covers at a swap meet father's day weekend. Got them stripped, cleaned, and painted last weekend. Slipped out to the shop last evening and swapped them out with the originals.
Next up is putting new speedo gear in the transmission to see if I can get it a bit more accurate. About 4-5 mph slow right now.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-27-2023, 03:28 PM   #3971
Chevys4life
That is a good trick to know.........thanks for the pointers Mark.
Chevys4life is offline   Reply With Quote
Old 06-28-2023, 12:09 PM   #3972
OregonNed
OregonNed's Avatar
I have my 4/5 drop completed with front disc brake conversion - drop spindles and 2" springs plus 3" springs in the rear (had 2 inch blocks prior) - very happy with all of the results.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 06-28-2023, 04:37 PM   #3973
samkost
samkost's Avatar
Great LWB stance Ned.
May I ask what size tires and wheels you are showing off.
Thanks, Sam
Old 06-28-2023, 05:21 PM   #3974
OregonNed
OregonNed's Avatar
Thanks, Sam
You bet! 15x7 up front with 235/70/15s and in the back, 15x8 with 275/60/15s
Old 07-01-2023, 05:10 PM   #3975
72c20customcamper
Put the hood on . Easy when you have 5 people helping took a few minutes to line up but the fit is very good hood latch isn’t on yet so it pops up
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
