Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WTB Parts
Old 06-26-2023, 06:30 PM   #1
irl104
Radiator Shroud for 6 cylinder
WTB. Looking for a plastic Radiator shroud for a 6 cylinder 292. Thank you.
irl104 is offline   Reply With Quote
Old 08-07-2023, 05:55 PM   #2
HWY-STAR
HWY-STAR's Avatar
Re: Radiator Shroud for 6 cylinder
Hello there. I have several fan shrouds but not sure for what radiator and engine set up. Can you help me identify what you need for your 6 cylinder.
Thank you. Dan
72 sierra grande 402/400
72 longhorn 402/400
67 swb fleet side 350/350 buddy buckets tack/vac dash project
71 Cheyenne c20 350/350 all original except seat cover-SOLD
1970 GMC 3500 SRW 350 4 speed-FOR SALE
72 c-30 bb 4 speed dump bed
72 k-20 4x4 350/350 patina rat rod---sold
80 chevy p20 aluminum step van 350/400 12 ft cargo
62 parts car & 63 project nova, 4 door 6 cy
74 Honda cb 360 only 4000 miles
HWY-STAR is offline   Reply With Quote
Old 08-07-2023, 09:20 PM   #3
irl104
Question Re: Radiator Shroud for 6 cylinder
Hi Dan.
I wish I could. Mine didn't have one on it and I don't know what it looks like. Thank you
Old 08-09-2023, 11:03 AM   #4
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
I'm pretty sure the six cylinders never had a fan shroud, just a finger guard. That's all my 250 had. My 292 never gets over 180 degrees anyway.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 08-09-2023, 04:07 PM   #5
irl104
They made them as a "Heavy Duty Radiator Fan Shroud". There was one listed on this site before. Thanks.
Old 08-15-2023, 07:45 PM   #6
CKfan
My 69 inline 292 came with the RPO option "heavy duty radiator" listed but had no fan shroud, just the finger gaurd. Good luck with the search. If found, please post a picture.
CKfan is offline   Reply With Quote
Old 02-19-2024, 10:28 AM   #7
old51sedan
old51sedan's Avatar
My 69 has a fan shroud that looks like it may have came on it from the Factory, has the old sticker on it. I bought this truck 8 years ago out of the desert in CA. I post a picture of it.
old51sedan is offline   Reply With Quote
Old 02-19-2024, 01:10 PM   #8
irl104
Can you tell if there are factory numbers on it anywhere? How many blades are on your fan? Thank you.
Old 02-20-2024, 10:44 AM   #9
oneshotkyle
Active Member
I just ordered a new 3 row brass/copper radiator along with a fan shroud for a non a/c sbc for my inline 6 last week from LMC. Should have it by thursday this week and i will keep you informed if it works out.
oneshotkyle is offline   Reply With Quote
Old 02-20-2024, 11:54 AM   #10
irl104
I ended up buying a fan shroud from LMC for a sbc and cut it out to fit. I’m still wanting an original one for it.
Old 02-20-2024, 03:21 PM   #11
oneshotkyle
Active Member
Whe you say cut it out to fit, what is it you cut out? Im under the assumption that inline 6 engines came factory with the narrower 2 row radiator which wont accept any fan shroud except the top metal cover. I was told that using the wider 3 row radiator in my inline setup would then allow the v-8 shroud to be used.
Old 02-20-2024, 04:06 PM   #12
irl104
I put in a three row factory radiator as well. I had to cut part of the side of the fan shroud out and the bottom so it would fit. My truck is a 1 ton chassis.
