06-26-2023, 10:47 PM | #101 |
Roto Reuter thats the name...
Re: Project "Buffalo Blizzard Surprise" 71 SWB build
Here goes the cab...
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
06-26-2023, 10:53 PM | #102 |
After about one month, Jesse was able to fit it in and get going on the blasting.
Cab turned out pretty good. I was pleased. Doors and hood turned out good too!!!
06-26-2023, 10:56 PM | #103 |
Both original fenders turned out nice. No rot or holes. Nice to have a truck that came from Arizona.
06-26-2023, 11:00 PM | #104 |
Get the parts coated before work begins on the body and panels.
06-26-2023, 11:03 PM | #105 |
Some rot was found, but not too bad.
06-26-2023, 11:05 PM | #106 |
Time to get the bad passenger side rocker fixed.
06-26-2023, 11:08 PM | #107 |
Bought some Slosh Tubz sheet metal for the firewall. Ended up not using the side filler panels.
06-26-2023, 11:11 PM | #108 |
Work gets underway smoothing out the firewall...
06-27-2023, 07:49 AM | #109 |
:Nice work …. Great progress …. ….now we can’t wait 4 years for what’s next
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
06-27-2023, 03:37 PM | #110 |
Subscribed!
My 1970 C10 ChassisFab LWB to SWB Build Thread |
07-01-2023, 09:16 PM | #111 |
Nope... I'm on it.
07-01-2023, 09:20 PM | #112 |
I wanted to try to use One Piece Products rear window, but it wouldn't fit right. When compared to my stock glass I could see that it was off slightly on the driver side. In order to use it I would have to tweak the window opening slightly. I'm debating.
07-01-2023, 09:26 PM | #113 |
Got the body work going on the firewall.
Closed off and welded the channel, all the way around.
07-01-2023, 09:32 PM | #114 |
Time to start shaving the drip rail. The plan is weld in a 1/4" dia piece of rod around the door.
07-01-2023, 09:39 PM | #115 |
More body work on the passenger side rocker.
07-01-2023, 09:42 PM | #116 |
Body work on the fuel filler hole.
Before.... After...
07-01-2023, 09:48 PM | #117 |
The only major rust on the truck was the rear window channel. Really lucked out with this original sheet metal. This will need some repair.
07-01-2023, 09:53 PM | #118 |
Needed to make a patch panel for the rear window channel. This was how it was done.
Finished piece. Just needed to cut out the old section and weld this in. Here we go...
07-02-2023, 05:40 PM | #119 |
Shaved the dash by removing the radio speaker hole and defroster vents.
Also more work on the shaved drip rails.
07-02-2023, 05:43 PM | #120 |
Some inside work to remove the radio and center vent. Making room for a double-din head unit.
07-02-2023, 05:47 PM | #121 |
Work on getting the cab into primer.
07-02-2023, 05:48 PM | #122 |
More work on the cab.
07-02-2023, 05:55 PM | #123 |
Put front end back together.
07-28-2023, 10:09 PM | #124 |
Drilled some holes in the firewall for my master cylinder and steering column. If you notice there's only two holes for the master and they're not studs. I drilled the stock pedal mount and installed rivet nuts in two holes for the master. This way I can use button head screws for a cleaner mount. The other holes have studs on the back of the firewall for mounting into the bracket.
07-28-2023, 10:18 PM | #125 |
I decided to install some Trique Altman Easy Latches for my doors. I'm also going to try the Honda door seals. Hopefully, I have some nice closing doors.
