04-14-2014, 10:35 PM | #1 |
Power Steering Pump Adaptation to GMC V6?
Any info or pics from folks that have mounted a later model pump to their GMC V6 engines? Working on my power steering conversion and would like to buy a pump...just curious if I am fabbing it all or if there is a combination of brackets that work?
04-15-2014, 07:20 PM | #2 |
Re: Power Steering Pump Adaptation to GMC V6?
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
04-15-2014, 07:22 PM | #3 |
You need to try and get the double groove pulleys for crank and W/P. That is half the battle.
Here is something I fabbed up using this EBay bracket and I think a Buick double groove P/S Pulley/Pump. I had a friend make me an extension to bolt up underneath. My fab skills are basic but this works. I have also seen some use the chevy big block type of pump with remote reservoir.
MusicMan70 1961 GMC Suburban |
04-15-2014, 07:23 PM | #4 | |
04-15-2014, 07:24 PM | #5 | |
04-15-2014, 07:32 PM | #6 |
Yes, I've seen some people use an idler pulley as well.
04-15-2014, 07:35 PM | #7 |
That makes sense. For me, I wouldn't mind having a separate belt running alternator and power steering just so losing 1 belt doesn't take it all out. I don't think losing a belt is much of a concern though.
04-15-2014, 08:02 PM | #8 |
There are 2 different size double grove pulleys that came on the V6, there also 3 grove pulleys.
04-15-2014, 08:25 PM | #9 |
Junior Member
If you are interested, I have a V6 power steering pump, brackets and pulleys, and adapters for steering box-to-frame.
04-15-2014, 10:20 PM | #10 |
07-02-2023, 03:43 PM | #11 | |
07-03-2023, 07:46 PM | #12 |
Ahaynes; The extension on bottom is offset.
The hole I drilled in the bracket arm that sticks out; all I did was remove that front bolt from the engine mounting plate and made a mark and drilled it. The lower extension not sure of measurement. I had to play around with it a bit to have one of the pulleys line up. I'll see if I can get you some better pics and a measurement.
07-04-2023, 01:52 PM | #13 |
Here’s the belt size I used and some extra pics.
07-05-2023, 01:23 PM | #14 |
08-09-2023, 02:38 PM | #15 | |
08-09-2023, 08:07 PM | #16 |
Your welcome Ahaynes;
Your set up looks great!
