Old 06-30-2023, 02:04 AM   #1
Chevy nutcase
Chevy nutcase's Avatar
Correct me if I'm wrong
Cruising the depths of marketplace for a local small block for a rebuild and I saw this. Ad says it's a 350 from an 80s pickup and I wondered why there was only 1 accessory hole in the heads. Then I saw the backside and I'm guessing they swapped sides with the heads for whatever reason or is there a breed of cylinder heads that are supposed to be like this? It's been a while since I rebuilt an engine
Chevy nutcase is offline   Reply With Quote
Old 06-30-2023, 08:45 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Correct me if I'm wrong
I believe that came from a 86-87 truck or van. 1pc rear main seal, 193 heads and 210hp.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Warrens69GMC is online now   Reply With Quote
Old 06-30-2023, 09:25 AM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
That is an 86 to 92 350. You will need to use an electric fuel pump. During casting they blocked off the fuel pump hole. I know the BB of that time did not. I have an 87 engine and this is how I know. Also the center bolt valve covers.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-30-2023, 10:08 AM   #4
Warrens69GMC
86-89 you could still get a mechanical fuel pump in the R series. It needs to be checked if wanting to run the mechanical pump.
I say its 86-87 because it doesn't have the lifter valley bosses cast into it.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 06-30-2023, 10:48 AM   #5
SCOTI
SCOTI's Avatar
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-06-2023, 11:09 AM   #6
MikeN
MikeN's Avatar
As far as I know there has NEVER been unique left or right cylinder heads for any SBC. They all fit either left or right. On a used engine it's always possible one of the heads has been swapped for a different casting number or model year.
MikeN is offline   Reply With Quote
