Old 07-05-2023, 05:14 PM   #1
Tmend
Tmend's Avatar
First timer here. Need help
I ordered this pan for my 5.3. My question is what dipstick and tube will work. The seller has not replied and there are many options out there. The 5.3 is going in a 72 2wd suburban. Name:  F6DC9E06-2770-4A23-B660-C299F7FC5D7C.jpg
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 07-05-2023, 05:33 PM   #2
mongocanfly
mongocanfly's Avatar
Re: First timer here. Need help
Will the stock the not work?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-05-2023, 07:22 PM   #3
Tmend
Tmend's Avatar
Wouldn’t know. My stock tube was broken. This pan is also about 2-3 less shallow. Not sure if the factory dipstick length would mark correctly.
Old 07-05-2023, 08:41 PM   #4
Custom 68
Custom 68's Avatar
You will probably need to find a stock one maybe from a camaro so its shorter. Once you fill it with the correct amount of oil per the manufacturer of the pan then mark the dip stick.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-05-2023, 08:48 PM   #5
LS short box
I've used Lokar on some of my LS swaps. See pic. You can just see the top of the dip stick is on the left side just below the coil cover. I use 2002 Camaro oil pans.2002 Corvette coil covers.
Another pic of a LS3 swap I used a stock LS3 Corvette dip stick using a 2002 Camaro pan. LS3 Corvette coil covers.
Best thing to do is put in 6? quarts in the pan and see how it reads on the stick and then mark the stick as needed.
Old 07-05-2023, 08:56 PM   #6
mongocanfly
One engine I got from a wreck ,the tube was broke..I used a lokar also..
I put 6 quarts in it and it was dead on the full mark
The fill it and see what you got is probably the best idea
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-05-2023, 09:02 PM   #7
Tmend
Tmend's Avatar
Thank you all for the advice
Old 07-06-2023, 07:59 AM   #8
Joyridin
That looks like a Holley knock-off pan. Go on Holley's site and get the instructions. They have all the information on which dipstick.
Here is the link for info on the 302-1 pan, which looks like yours: https://documents.holley.com/199r10566rev8.pdf
Joyridin is offline   Reply With Quote
Old 07-06-2023, 04:20 PM   #9
Jason Banks
Jason Banks's Avatar
That's what I was thinking Joyridin, is uses the LS3 dipstick and tube. I ended up buying the Dorman parts instead of GM
DORMAN 921-045
DORMAN 921-044
Jason Banks is offline   Reply With Quote
Old 07-06-2023, 05:59 PM   #10
Tmend
Tmend's Avatar
DORMAN 921-045
DORMAN 921-044
Thank you I just ordered these parts
Old 07-07-2023, 07:12 AM   #11
A1971Blazer
A1971Blazer's Avatar
My LS1 came from an F-body, I swapped the pan to the GM performance 19212593
Muscle Car Oil Pan Kit. It came with a new dip stick and tube.
I tried looking up the part numbers but couldn't find them listed individually.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-07-2023, 08:39 AM   #12
cj847
cj847's Avatar
I think I am recalling correctly here. The dip stick mounts to the block and is not affected by the oil pan. Regardless of what the upper part of it looks like, the distance from the mounting point to the full mark is the same. (The different shapes, lengths are due to vehicle packaging).
cj847 is offline   Reply With Quote
Old 07-07-2023, 10:43 AM   #13
hewittca
hewittca's Avatar
That's what I was thinking as well cj847 when I needed to replace my tube. Seems like the stock one should work, however, I went ahead and replaced mine with the part numbers suggested by Holley. I have this same knockoff pan on a 2004 5.3 and I went with the GM parts. They ended up being sub-par quality. The dipstick end didn't even fit through the end of the tube and I had to ream it out! I'm curious to hear how the Dorman parts fit.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 07-07-2023, 11:19 AM   #14
Jason Banks
My dorman fit good, but I did read some reviews that said they had a similar problem you mention...
