Old 07-01-2023, 06:51 PM   #1
Ironhorse
Ironhorse's Avatar
Lug Wrenches
Have two lug wrenches, one fits 3/4'' lug nuts for 1/2 ton and one fits 13/16'' lug nuts for 3/4 ton. Both marked with an " O " on the bell section, bead blasted, primed and painted satin black. Good sharp beveled ends with no damage. $20 choice plus shipping, money order do not have Paypal.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 07-01-2023, 08:05 PM   #2
Utahboy
Re: Lug Wrenches
I will take them both please. Shipping to 48451. Thanks
Utahboy is offline   Reply With Quote
Old 07-01-2023, 09:37 PM   #3
Ironhorse
Ironhorse's Avatar
Re: Lug Wrenches
Both lug wrenches SOLD to Utahboy, thanks for the purchase. Sending PM.
Wellington, Ks
Old 07-08-2023, 04:17 PM   #4
Ironhorse
Ironhorse's Avatar
Re: Lug Wrenches
Utahboy, received payment in the mail today. Will ship Monday and PM the tracking numbers to you. Thanks again for the purchase,
Wellington, Ks
Old 07-10-2023, 09:19 PM   #5
Ironhorse
Ironhorse's Avatar
Re: Lug Wrenches
Lug wrenches shipped this morning and PM sent with tracking numbers.
Wellington, Ks
Old 07-10-2023, 09:53 PM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Lug Wrenches
Hey I got a question. Wish I had my original nuts for my C10 but don't. I've always thought they were 3/4" hex for my truck.
I bought OEM nuts from a board member that are 13/16" hex with correct 1/2 x 20 threads and installed them with fresh wheels and hub caps - fits like a glove.
Figure they're later model lug nuts or?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-10-2023, 10:20 PM   #7
Ironhorse
Ironhorse's Avatar
Re: Lug Wrenches
No expert for sure as still learning after a good number of years playing with trucks but....the 3/4'' lug wrench I matched up to the lug nuts that came on a 67 GMC 1/2 ton of my BILs. The 13/16'' lug wrench I matched up to the lug nuts that came on a 70 Chevrolet 3/4 ton I parted. Thinking a C30 or 1 ton uses 7/8'' lug nuts originally. Hope that helps out altho possible lug nut size and thread size can be of changed thru the years.
I do have a couple more 3/4'' and 13/16'' lug wrenches I have not cleaned up yet if you have an interest. LMK.
Wellington, Ks
Old 07-11-2023, 12:04 AM   #8
71CHEVYSHORTBED402
Re: Lug Wrenches
I'll have to check what I have, thank you for the offer and info.
Tony
Old 10-31-2023, 07:41 AM   #9
G-749
Junior Member
Re: Lug Wrenches
My 70 c20 longhorn has the 13/16 lug nuts on the rear and the 7/8 on the front, it also has disc brakes on the front. All of the ball joints have been replaced as they all have the rivets drilled out and replaced with bolts/ nuts. Purchased truck 2 weeks ago ,joined site also. Good move on both. Been trying to search for reason for different lug nut sizes on front and rear. Newbie just wondering. Thanks, good luck on all your projects
G-749 is offline   Reply With Quote
Old 10-31-2023, 09:07 AM   #10
Ironhorse
Ironhorse's Avatar
Re: Lug Wrenches
G-749, with your 70 having disc brakes and 7/8 lug nuts I suspect at some point a previous owner changed to a newer one ton front end. No disc brakes from the factory until 1971. Not an expert by any means but thinking the front end suspension was changed for the disc brake option and the one ton trucks also used the eight lug wheels as do the 3/4 ton trucks.
Welcome aboard to the best GM truck forum on the net and good luck with your recent truck purchase.
Wellington, Ks
