Old 08-13-2004, 09:44 PM   #1
richardwilken
Exclamation Dana Pics
Looking For Pics Of Open And Closed Knuckle Front Axles (dana's). Also, Looking For Information On Disc Barke Conversions For Dana 44 Front Axles. Any Body Help? Thanks
69 chevy 1/2 ton 2wd
72 GMC 1/2 ton 2wd
richardwilken is offline   Reply With Quote
Old 08-14-2004, 09:28 AM   #2
Yukon Jack
Yukon Jack's Avatar
Here's my 69 K20 closed knuckle Dana 44. 1969 was the last year for this design.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-14-2004, 09:29 AM   #3
Yukon Jack
Yukon Jack's Avatar
You can switch out the knuckles to go with disks but most people just swap in a newer Dana 44 with disks rather than messing with the conversion.
Old 08-14-2004, 10:34 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My 70 has open knuckle w/ drums and my 71 has open knuckle w/ discs, you could just swap everything from the knuckle out but usually it's easier to find a complete front axle from a 71-87 truck or -91 for blazer / suburban. It was thought that you could swap spindles and backing plates from a disc 44 to a drum 44 but it clocks the caliper back or forward depending on how you put it on. On a closed knuckle front you will not be able to convert to discs. I had a lot of pics but they are on another computer w/ a virus! So after the storm I could shoot some pics.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-14-2004, 12:45 PM   #5
Budweis
Geared for Collision
Budweis's Avatar
heres open one like jim talking about. im going to be using it as a doner and just swap knuckles out onto my other differential as im replacing u-joints, ball joints, seals, etc anyway and want to keep old one for the gears.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 08-15-2004, 12:54 AM   #6
67cst
i love summertime
67cst's Avatar
what are the advantages/disadvantages to open and closed knuckles?
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 08-15-2004, 02:19 AM   #7
1969 GMC
1969 GMC's Avatar
Derek, there is only one advantage to closed knuckle axles over open that I can see, is that they have kingpins instead of balljoints, which are a little more tough.
Downsides to closed knuckle: drum brakes only, external hubs (which arent desireable), smaller axleshafts, smaller ujoints at the knuckle, axle seals frequently go bad on these and make a mess. Also, closed knuckles cannot turn as tightly as open knuckles and therefore have a larger turning radius.
Open knuckled axles are pretty much the opposite. '70 models with drums can be converted to discs, otherwise all other years have discs to begin with. Most have internal hubs, but some still have external. These axles also have larger shafts and u joints, and dont have annoying tube end seals to make a mess. Also you get an improved turning radius.
The closed knuckle d44 in my truck was fine for DD duty (4 wheel drum power brakes) and light wheeling with my 32's, but since I plan on lifting my truck and getting bigger tires, the axle and those weeny little drums up front had to go. I would have gone to a newer d44 with open knuckles, but lucky for me I got a hella deal on a d60 for $150.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-15-2004, 04:27 AM   #8
67cst
i love summertime
67cst's Avatar
adam thanks for the info, im just getting into the 4x4 scene, i wasnt going to post until tomorrow when i got pics but i think im snagging my buddies 63 gmc 4x4, he put over 12k into it and now is strapped for cash cause he bought a house and a new truck, so im really concidering it,id say there is a 99 percent chance of it anways, its sitting on a 79 3/4 ton frame, so its got disc brakes, power steering and power brakes, for running gear it has a 383 stroker push a little over 400 hp, or so he says, and a th400, new 33's too, decent paint, very clean interior, new exhaust..over all its a tight rig, im going to get pics tomorrow after lunch and ill post em on here and see what everyone thinks, like if the price is right etc. im pretty stoked about it though, its a pretty tough looking truck, the only think im not happy with is that its on propane, but id swap that back to gas in a heartbeat, especailly with the newer frame and all, i could probably find a tank for it at the local wreckers
anyways enough b.s for now....ill post pics tomorrow
Old 08-17-2004, 01:10 AM   #9
richardwilken
where could i find a conversion kit for this? what other parts need to be converted? these drums just dont cut it for trailer towing (esp. stopping). i have looked into finding a d44 from a 71 0r 72. what kind of price am i looking at, providing that i can find one? i know 73-87's had them, but would prefer an original. any help?
72 GMC 1/2 ton 2wd
Old 08-17-2004, 02:28 AM   #10
Budweis
Budweis's Avatar
your on the right track just need to get one off a 71-72, somebody on here might have one near you. should be able to get one for somewhere around 125.00 to 150.00 if you catch someone upgrading.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 08-17-2004, 05:01 AM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The actual dana 44 was available until around 78 in the chevys and later in the GMCs. The 73 and newer axles will have a slightly larger axle u-joint, which is desirable. While finding a 71-72 would be nice, I'd say start by looking for a gear ratio that matches your rear or what you want then go from there. You could broaden the search if you include the 10 bolt available up to 87 or 91 depending on truck or suv. One of the biggest differences would be a metric banjo fitting at the caliper.
Old 08-17-2004, 01:24 PM   #12
Grim Reaper
Scrap any pre disc D44 unless your doing a 100 point restore. It's not worth the time to mess with if you building a truck to use.
When looking for a replacement get a 74 or newer. 73 and older ran smaller u-joints. I 147 or something. the 74 up 1/2 and 3/4 run a 297. The disc front ends made 70-73 can swap to the larger u-joint axle shaft no problem.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-17-2004, 06:54 PM   #13
Txstruck
Txstruck's Avatar
Heres a page that shows everything about a Dana60:
http://www.coloradok5.com/dana60manual.shtml
Steve
86 K30 4x4 6.2L Diesel\TH400\NP208 - 14bolt FF rear w/detroit locker and Dana60 front w/detroit locker- both with 4.56 gears "Runs on Mud"
Txstruck is offline   Reply With Quote
Old 08-18-2004, 12:40 AM   #14
richardwilken
this truck is meant to be driven. they way i figure it, my options are:
1. 74 and up d44 (or d60)
2. find an original 71-72 d44 with front discs.
what has to be modified to fit a 73+ d44 to our trucks? spring perches on the axles? etc, what else? i want to keep my 8 bolt wheels. is the track width of the axles different?
thanks for all the help!
72 GMC 1/2 ton 2wd
Old 08-18-2004, 01:41 AM   #15
1969 GMC
1969 GMC's Avatar
I am pretty sure that all newer d44's and d60's will bolt right up. Also, all 3/4 ton d44's will be 8 lug, and all d60's will be as well. even the 10 bolt should bolt up, but I don't know much about this axle.
1969 GMC K2500
1996 Honda Accord
Old 08-18-2004, 04:51 AM   #16
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Like Adam said, the axles will bolt right up. I was under the impression that the late 72 axles got the larger u-joints as well as 73 and up. The dana 60 appears in the late 70s under 1 tons. Steering correction is the same, i.e. raised arm or dropped pitman arm they are the same, 70 through 87 or 91(truck-suv).
Old 08-18-2004, 10:41 AM   #17
Scrubby
Check out GMTrucks.org
Yes, they bolt right up. I have a '76 D44 under the front of my '72. Another nice thing that came with the newer axle was the stock steering stabilizer.
Good luck finding a cheap D60! 1969 GMC must have held someone at gunpoint to get one for $150. Going price is about $1000 for an axle that needs to be rebuilt. Atleast out here in Idaho.
Scrubby is offline   Reply With Quote
Old 08-18-2004, 11:06 AM   #18
Grim Reaper
I'm not positive of the date of change over but I kniow for a fact that it happend by 74. I have run across a few external hub 8lug D44's on 73's in junk yards. By 74 all were the internal hub so again another vote for that because it's easier to get parts for. Every Advance is going to have Warns that fit.
Any solid axles from a 1/2-1 ton up to 91 will bolt right in. I have heard that the 10 bolts from 78 up run larger wheel bearings so that might also be somethign to look at. The down side of the 10 bolts is no flat top knuckle if you want to do a cross over later.
Grim-Reaper
Old 08-18-2004, 12:36 PM   #19
1969K10
1969K10's Avatar
Closed knuckle dana 44
Ok, I probably should have started a new thread, but i'm looking for some help. As you can see from the grease, i need to install new axle seals. I've got (2) different questions. My hubs are different, the pass. is a Warn M-198. the driver side is a Warn M-4. I didn't do this. My first question is will the same hub tool work on both? My second question, is what is the plate at the bottom of the end with the (4) bolts, and what does it do? I have tried to attach pictures of both hubs, the first is the pass side (M-198), the 2nd is the driver side (M-4).
Thanks.
1969K10 is offline   Reply With Quote
Old 08-18-2004, 02:58 PM   #20
charlieo
pin & brgs
That greasy old plate w/ the 4 bolts holds in a pivot pin (king pin)& a bearing (timken) for the turning of the knuckle .
charlieo is offline   Reply With Quote
Old 08-18-2004, 05:14 PM   #21
richardwilken
so adam and jim, and everyone else; what you're saying is that 73 and newer D44 or D60 or 10 bolt will bolt right up without moving the spring perches? And the axle widths are the same? just making sure, because I remeber reading on here where people have said they have to weld the spring perches on in a new place. i only want to do this once and do it right. thanks for all your help. i may have found a 71 0r 72 D44. do you suggest going this route, or getting a 73 and newer one with larger u-joints?
Am i a pain in the a** or what!
72 GMC 1/2 ton 2wd
Old 08-18-2004, 05:27 PM   #22
Scrubby
Yes, the newer fronts bolt right up. I think they changed the distance between the spring perches on the rears in '73, so you might have read about someone swapping in a newer rear and having to move the spring perches.
Old 08-18-2004, 05:34 PM   #23
1969 GMC
1969 GMC's Avatar
the rear axles are the only ones that will need the perches moved, and that is only on '73 and up 3/4 tons. the 1 tons are the same width as ours.
oh, and i didnt use a gun to get my d60 for $150. but for some reason, the same jy guy that wants $1600 for a running 454 and $25 for a mirror head only wanted $200 for the d60, and i talked it down to $150 but it needs a TOTAL rebuild.
1969 GMC K2500
1996 Honda Accord
Old 08-18-2004, 09:39 PM   #24
richardwilken
thanks for all your help guys! any other suggestions?
72 GMC 1/2 ton 2wd
