Old 07-08-2023, 10:22 PM   #1
CarlsLQ9SS
CarlsLQ9SS's Avatar
Power steering pulley and crank pulley information
Anyone know anything about these pulleys?
Carl
1971 GMC short bed, (Henry)
Options I've added, tilt, ac, 8k tach,
Electric speedometer conversion for LS swap,
6.0 with 823 heads and BTR stage 4 truck cam,
4L80e, posi with 3.73 rear end,
Power steering and power brakes
Lowered 5/7. Frame up build.
CarlsLQ9SS is offline   Reply With Quote
Old 07-09-2023, 01:17 AM   #2
kwmech
Re: Power steering pulley and crank pulley information
Crank pulley assy with AC and a power steering pulley
Old 07-09-2023, 08:22 AM   #3
CarlsLQ9SS
CarlsLQ9SS's Avatar
Thanks for the info, I never seen a cast iron crank pulley before and searched and found the power steering pulley was used on big blocks. I couldn’t hardly make out the crank pulley part number and figured someone here would know what combination it was for.
Carl
Old 07-09-2023, 08:34 AM   #4
Sheepdip
Sheepdip's Avatar
Looks exactly like the factory set-up on Otis.
Sheepdip is offline   Reply With Quote
Old 07-09-2023, 10:57 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Cast iron pulley looks like it’s been welded on.
You might want to find another one, just to be safe.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 07-10-2023, 05:29 AM   #6
CarlsLQ9SS
CarlsLQ9SS's Avatar
I think that’s dried oil from a past oil leak, I’ll look closer when I get home from work.
Carl
Old 07-11-2023, 07:59 AM   #7
MARKDTN
I have never seen cast crank pulleys on anything automotive. I would have assumed a marine application. Interesting.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-11-2023, 09:28 AM   #8
lolife99
lolife99's Avatar
No. Those cast pulleys were correct add on power steering pulleys for the 67-72 trucks.
I’ve had many of them.
Keith
Old 07-11-2023, 07:43 PM   #9
CarlsLQ9SS
CarlsLQ9SS's Avatar
I learned something else new about these trucks!
Carl
Old 07-11-2023, 08:13 PM   #10
RichardJ
I had a cast pulley like that as part of a aftermarket AC system . It used one of those old York Compressors. The evaporator that hung under the dash was the size of a steamer trunk.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 07-11-2023, 11:13 PM   #11
mr.mud1
mr.mud1's Avatar
i thought the cast pulley looked funky too but it maybe just old oil,dirt and grease dried up but certainly it wouldn't be wise to use it,if it had been welded on.my big block 72 truck with factory A/C has 2 pulleys on the crank,both steel not cast.i have a couple cast crank pulleys here,i seem to recall they were on 62-64 283's or 327's in fullsize cars?
mr.mud1 is offline   Reply With Quote
Old 07-12-2023, 05:14 AM   #12
CarlsLQ9SS
CarlsLQ9SS's Avatar
It was dried oil and dirt from a past oil leak.
Carl
