Old 07-10-2023, 11:42 AM   #4001
OregonNed
OregonNed's Avatar
Re: What did you do to your truck today.The 3rd chapter
Refurbished the stock front sway bar after the drop and also got the alignment done - lastly paid $107 to top off the tank for a show Saturday..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 07-10-2023, 12:44 PM   #4002
pjmoreland
pjmoreland's Avatar
Started the process of installing a Gen 5 Vintage Air kit. Removed the original heater box and painted the blanking plate that takes its place. Just stuck it on there temporarily to see how it will look.
Since the inner fender had to come out to get the heater box out, I took the opportunity to weld up 5 holes that a PO drilled in it. Afterward, the paint I sprayed on it reactivated the paint underneath, making a big mess. I may have to strip it to bare metal and start over.
Also deburred and painted the compressor mounting brackets. I'm thinking about maybe painting the compressor black.
pjmoreland is offline   Reply With Quote
Old 07-10-2023, 01:37 PM   #4003
Mryan
Active Member
Grind, grind, grind
Mryan is offline   Reply With Quote
Old 07-10-2023, 06:40 PM   #4004
'68OrangeSunshine
'68OrangeSunshine's Avatar
Pat, Do you get a heater with your Gen 5 A/C unit?
Old 07-10-2023, 07:05 PM   #4005
pjmoreland
pjmoreland's Avatar
Yes. It's got the evaporator and the heater core both inside the same box that goes under the dash. It cleans up the firewall, but the bummer is that you lose most of your glovebox.
Old 07-10-2023, 09:52 PM   #4006
'68OrangeSunshine
Does Rocky Raccoon have a console between buckets?
Old 07-10-2023, 10:07 PM   #4007
pjmoreland
pjmoreland's Avatar
Good point. Yes
Old 07-11-2023, 12:41 AM   #4008
'68OrangeSunshine
Good point. Yes
So you don't need that much volume in the ''Dispatch Box.'' [As our Canadian neighbors call the Glove Box.]
Old 07-11-2023, 01:54 AM   #4009
19gmc72
Got the cab in epoxy. Realized I need a better “paint booth” and more time behind the spray gun. Next up is the floorboard.
1969 Chevy C20
1972 GMC K25 Sierra Grande
http://67-72chevytrucks.com/vboard/s...d.php?t=846326
1988 Toyota Xtra Cab 4x4 22re
2003 Chevy 2500HD 6.0
2007.5 GMC 2500HD LMM Duramax
19gmc72 is offline   Reply With Quote
Old 07-11-2023, 11:31 PM   #4010
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Originally Posted by Casper42 View Post
installed a bowtie compass. I found this location to be best, minimizing the interference from metal and magnetized items in the dash.
That's very cool, and beautiful interior
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-15-2023, 05:22 PM   #4011
pjmoreland
pjmoreland's Avatar
I'm cutting up the dash I installed a couple years ago to replace a cut up dash. Doesn't feel right.
Old 07-15-2023, 06:45 PM   #4012
'68OrangeSunshine
I'd like to restore A/C on the '71 GMC Jimmy. It had Factory Air when new, but the PO let it go by the time I bought it [1995]. Furthermore --maybe 25 years ago -- I removed a lot of the A/C paraphrenalia and put the parts in a bucket. Then I lost the bucket. Never had the compressor or mounts. So I'd be starting from square one to install A/C. At least the dash vent holes are in the right places -- don't have to cut.
Old 07-16-2023, 09:58 AM   #4013
Chevys4life
Put some of my old school decals on the old boy this weekend.
Chevys4life is offline   Reply With Quote
Old 07-16-2023, 05:25 PM   #4014
72c20customcamper
72c20customcamper's Avatar
Not a great day weather wise but I took off the parking brake lever on the 68 why would they go to the trouble of taping off the lever ? Need to get a cable too
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-16-2023, 05:35 PM   #4015
'68OrangeSunshine
Get a better grip, maybe? Or to cover the fact that the black paint wore off and it was rusting around the periphery. On my '68 C/10 Stepside, the part of the handle that was in daily contact had rubbed itself to shiny metal -- rusting into black paint outside of the contact area. I re-shot it with Satin Black during a 2005 engine rebuild.
Maybe they taped the steering wheel too, and matched the brake handle to it.
Too many variables to know for certain.
Apologies if I answered a rhetorical question...
Old 07-16-2023, 05:40 PM   #4016
72c20customcamper
Sure they used a template . The handle is nicely painted and held up well . Just an observation as a little overspray line would have been acceptable . Specially with all the runs my dash had .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-16-2023, 06:43 PM   #4017
72c20customcamper
Love the Rust 911 non acid rust remover . One hour soak
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-16-2023, 06:49 PM   #4018
'68OrangeSunshine
Will you paint it?
Old 07-16-2023, 07:08 PM   #4019
72c20customcamper
Cleared the bare steel . Going to paint the black tomorrow.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-16-2023, 10:03 PM   #4020
tutone
tutone's Avatar
I changed both rear brake cylinders on the 71.
No more seeping I hope.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 07-16-2023, 10:04 PM   #4021
tutone
tutone's Avatar
Duplicate post. Sorry.
Old 07-17-2023, 03:12 AM   #4022
pjmoreland
pjmoreland's Avatar
Installed the A/C condenser. Routing the lines through the core support was a challenge without removing the grille. Also installed the compressor and figured out the right belt length (Gates 7570). Discovered my lower radiator hose interferes with the belt, so I purchased one that's the right shape and will install it tomorrow.
Old 07-17-2023, 06:21 AM   #4023
'68OrangeSunshine
Installed the A/C condenser. Routing the lines through the core support was a challenge without removing the grille. Also installed the compressor and figured out the right belt length (Gates 7565 barely goes on). Discovered my lower radiator hose interferes with the belt, so I purchased one that's the right shape and will install it tomorrow.
Nice work, Pat.
I tightened the two 9/16 bolts holding my thermostat down on the '71 GMC. I found a pint of bottled water on the cab floor. It was at least 140*. I topped off my recently resoldered radiator with it. Waited for the last bubble and surprisingly the whole 16.9 oz went in up to the neck.
My puke tank project on the 350 has yet to fill the Nova-type reserve container. There are scales of green antifreeze solids forming on the fore manifold top, all around the Thermostat neck. I put a new 160* stat in, in April. I used the provided paper gasket, but used no RTV.
Maybe I need to.
Old 07-17-2023, 09:30 AM   #4024
72c20customcamper
Come to the realization that the parking brake handle was dipped not sprayed .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-17-2023, 11:54 AM   #4025
LNP
Maybe it was powder coated
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
