Old 07-19-2023, 09:29 AM   #7
MalibuSSwagon
Re: LS Swap Pedal Bracket
Originally Posted by cdub2010 View Post
Im not sure why you need to buy a bracket, a flat piece of steel works fine. My k30 setup is attached. I haven't driven it yet but it feels solid and the pedal has full movement but needs to be moved a bit to the right for better a fit. I may not keep this as im not sure it will work with my current 8.1 vortec setup.
My first swap in a 77 k25 I used a gmt400 diesel pedal, it bolted right in, no bracket needed. That pedal is to sensitive for my liking, which i why im thinking about a dbc setup.
I'd prefer to stay with DBC, but I'm swapping to a GEN4 LS2 from my Gen3 5.3, so I have to use DBW. I can easily design a bracket and cut it on my plasma table, it doesn't have to be fancy.
What pedal is that? The monte carlo one?
MalibuSSwagon is offline   Reply With Quote
