Old 07-18-2023, 02:27 PM   #1
flyboyjack
flyboyjack's Avatar
I'm flumoxed
Hey Folks,
it's been a long time for me,.... lost my '71 C10 Cheyenne Super in an accident and sorta quit for a while. (Should have stayed "quit").
I bought a '63 C10 long bed stepside from a collector/dealer of sorts. If he could have, he'd have lied about how much air pressure was in the tires.
Anyway, I'm now in the throes of trying my best to get this "steed" back to reliability and roadability. Both are a challenge and expensive.
Here's my dilemna: Living in southwest Florida, the outside temps as in most of the USA are sky high. Suddenly with the A/C on, the temps immediately go to 220 and stay there. At idle and even driving at 45-60 would not bring the temps down. As soon as I turned off the A/C temps came back to 190.
So I changed out the fan. Installed a Flex-a-Lite 3000cfm and cut 6 3" holes into the shroud with "flappers". This helped the temps, but the puzzling thing is that at road speeds 45-70 MPH, the temps slide up to 210-215 from 190 (A/C is on). Then when back in stop and go driving, the temps fall back to 190 or so, (A/C still on).
I currently have merely a single core. Trying one fix at a time. It seems the new fan gives me better temps, but I cannot understand why highway driving raises the temps and stop and go brings the temps back to "Normal"). Obviously there are no hills,.. it is flat Florida
Anyone got any thoughts/help?
Thanks.
Jack
flyboyjack is offline   Reply With Quote
Old 07-18-2023, 07:52 PM   #2
350TacoZilla
Re: I'm flumoxed
I would try a small drive with your bypass flaps taped shut or maybe do one side at a time. you might be bypassing the fan too much at speed so while the air from grille is cooling truck the fan isn't helping it along. I haven't had great luck with aftermarket fans\shrouds so I usually scavenge something from a newer vehicle at junkyard that fits decent and go from there.
350TacoZilla is offline   Reply With Quote
Old 07-18-2023, 08:21 PM   #3
geezer#99
geezer#99's Avatar
Re: I'm flumoxed
What do you have for a fan shroud?
Do you have pics of it and your engine bay?
Old 07-19-2023, 12:18 AM   #4
dmulally
Re: I'm flumoxed
Would be good to see a pic. I had a trans cooler in front of my radiator and and heating problems. I ended up moving it to under the passenger floor with a strong fan extracting the hot air from it and it fixed my overheating dramas.
So perhaps have a feel for how hot the condenser is getting?
dmulally is offline   Reply With Quote
Old 07-19-2023, 09:54 AM   #5
flyboyjack
flyboyjack's Avatar
Re: I'm flumoxed
The temp conundrum happened before i modified the fan shroud with the pass through holes. The temps actually improved with my new "design"/fix. The shroud itself seems well built designed. It's aluminum, has about an inch and a half to two inches from back of radiator fins to the fan and is as airtight as it can possibly be. The shroud covers 100% of the radiator.
Jack
Old 07-19-2023, 10:32 AM   #6
flyboyjack
flyboyjack's Avatar
Re: I'm flumoxed
No pix. The shroud is made of welded aluminum bar and solid aluminum sheet. (1/8"). The unit is as airtight as it can possibly be made. The shroud covers the entire radiator. There is at least 12" of clearance from the back of the fan/shroud to the front of the sbc motor. I don't know if it's a combination of the higher cfm fan and/or the pass through holes I made but the temps are at least manageable now. I just can't figger out how highway cruising results in higher temps than slow city driving. (Unless the fan which is always running is actually reducing the airflow).
Jack
Old 07-19-2023, 10:35 AM   #7
flyboyjack
flyboyjack's Avatar
Re: I'm flumoxed
Nothing blocking the condenser other than the poor air openings from the factory design of the grill and hood. The A/C air feels significantly cooler now. I'll shoot the condenser with a laser to see what temps it shows.
Jack
Old 07-19-2023, 10:45 AM   #8
geezer#99
geezer#99's Avatar
Re: I'm flumoxed
Could be your shroud is blocking enough air at higher speeds to make the temp climb.
Try removing it and see if that helps.
Old 07-19-2023, 12:55 PM   #9
Agv63
Re: I'm flumoxed
Just some food for thought, how clean is the core on inside, i had a case once where tubes were blocked internally and did the same thing.
In town all good but freeway driving it kept climbing.
Agv63 is offline   Reply With Quote
Old 07-20-2023, 09:15 AM   #10
MikeN
MikeN's Avatar
Re: I'm flumoxed
I believe this is your answer. Electric fans work great at idle, but at speed they block air from flowing through the radiator. There is a discussion about this exact issue over on chevelles.com. You might try experimenting with removing the electric fans, bolting on a simple mechanical fan, and seeing if your truck stays cool at cruising speeds.
https://www.chevelles.com/threads/co...1160281/page-3
MikeN is offline   Reply With Quote
Old 07-20-2023, 11:19 AM   #11
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: I'm flumoxed
Are you running the Chevrolet Cool Pack as an A/C unit ?
Old 07-20-2023, 10:42 PM   #12
Wrenchbender Ret
Re: I'm flumoxed
If you mean "single core" you are referring to the radiator size you need much more radiator. Get an aluminum radiator with a thick core.
George
Wrenchbender Ret is offline   Reply With Quote
Old 07-21-2023, 12:26 AM   #13
SkinnyG
SkinnyG's Avatar
Re: I'm flumoxed
When you say immediately, do you mean like right-freaking-immediately, as in: there is no way the engine could actually be heating up that freaking fast?
If so - Is it an electric temperature gauge? Could be a resistance issue with the A/C being on, messing with the gauge.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-21-2023, 10:04 AM   #14
dagnabbitt
dagnabbitt's Avatar
Re: I'm flumoxed
Fans have not been installed backwards by any chance. That happens.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
