Old 07-23-2023, 12:34 PM   #4051
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today.The 3rd chapter
Reconditioned seat belts installed . Not sure how but I managed to loose one of the bolts . So one of the latch belts isn’t bolted in it’ll turn hopefully.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-23-2023, 06:44 PM   #4052
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by pjmoreland View Post
I noticed that my truck runs cooler after I added the puke tank. I'm assuming it's because now the radiator can be filled all the way to the top.
I may be afraid it's stuck at 180*. It is all the way left when cold, but not an instant reading. It takes a while for the gauge to start indicating. The only time I saw it climb into the 212 - 220 range was when the copper brass tank ruptured. I was a half milr from my house. After an excruciatingly long stoplight, I pulled into a gas station/convienience mart [Speedway] and bought 2 gallons of chilled drinking water. 4 bucks and change. I could have tried their quarter-eating pay-water station, but it looked like a converted PacMan machine, and I didn't trust it. I was also really thirsty. So I overfilled the radiator, it cooled down, and I got home and pulled the GMC radiator.
Pulling the sender probe and immersing it in a can of just-boiled water -- to see how close to 212F it reads would be the textbook gauge check. But I'm not keen on messing with it. When the Jimmy got a fresh crate engine in 1999, the original Electric Temp gauge wouldn't play.
Old 07-23-2023, 07:13 PM   #4053
doug_p
doug_p's Avatar
Working on replacing a leaky 2 piece fuel line from the regulator to the fuel rail with a single PTFE line. First time trying to assemble the PTFE fittings and so far they are no joke. I'll keep at it until they are good to go. DP
Doug P
Yorktown, Virginia
1962 C10 LBFS - in pieces currently
1967 C10 SBFS
and a couple non-trucks
doug_p is offline   Reply With Quote
Old 07-25-2023, 11:45 AM   #4054
don t. - 72gmc
Finally getting off my rump to get my truck functional again. Completed brake line routing, install power booster and master. Installed new radiator. Cleaned up and installed fan/clutch/shroud. Bolted steering column back in. Rebuilt q-jaet carb. Still have a to-do list but progress nonetheless.
Havin fun...Don.
don t. - 72gmc is offline   Reply With Quote
Old 07-25-2023, 05:32 PM   #4055
body bolt
Originally Posted by body bolt View Post
I intentionally drove off a curb I thought would be no problem and knocked my exhaust pipe loose. Guess what I'm doing tomorrow...
It turned out to be worse than that. The right-hand exhaust manifold was broken at the collector so borrowed one from my Land Cruiser.
body bolt is offline   Reply With Quote
Old 07-25-2023, 06:50 PM   #4056
pjmoreland
pjmoreland's Avatar
Finished installing A/C
pjmoreland is offline   Reply With Quote
Old 07-25-2023, 07:09 PM   #4057
72c20customcamper
Cool sorry had to do it
Going to be nice riding in AC
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-25-2023, 07:12 PM   #4058
72c20customcamper
Put another rebuilt carb in my 68 Golden runs much better
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-25-2023, 08:17 PM   #4059
'68OrangeSunshine
Carter AFB?
Old 07-25-2023, 08:20 PM   #4060
'68OrangeSunshine
Way Cool, Pat.
Now I'm interested. Do you think it would work in a topped Blazer/Jimmy? Probably 3 times the interior volume...
And would it work against Arizona Summer Heat?
Old 07-25-2023, 08:21 PM   #4061
72c20customcamper
Originally Posted by '68OrangeSunshine View Post
Carter AFB?
Very early Edelbrock so yes basically an AFB . Edelbrock bought the rights to them and from what I have heard both came down the same line at Webber
Same exact carb that’s in my Avanti . I must have twenty AFB carbs sitting on a shelf at my moms place Dad would by any he saw . I have a NOS one for an Avanti in the box with all the correct tags
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-25-2023, 08:30 PM   #4062
'68OrangeSunshine
I agree, Same/Same.
I put a 350 crate motor in my '71 Jimmy in 1999. I got a Weiand intake and a Carter AFB Performance Series.
When I rebuilt a 292 L6 for my '68 C/10 Stepside, the Holley R8007 390 CFM carb was shot -- after only 25 years and 250,000 miles! So I looked for another Carter, but Federal Mogul had lost interest in the Hot Rod Aftermarket, so the only option was an Edelbrock 1404 w/ 500 CFM.
Very happy. I prefer the AFB style for ease of maintenance.
PS. You need to cap that other vacuum port.
[Unless the photo is a work in progress...]
Old 07-25-2023, 08:30 PM   #4063
pjmoreland
pjmoreland's Avatar
Way Cool, Pat.
I'm not sure. It seems pretty well-sized for a regular cab. I am finding the fan needs to be turned down after running on full blast for about 5 minutes. Is your roof insulated?
Old 07-25-2023, 08:40 PM   #4064
72c20customcamper
I agree, Same/Same.
If you mean the one circled it’s been epoxied . This was on the AMX when I had 2 carbs on it
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-25-2023, 08:43 PM   #4065
'68OrangeSunshine
It's a Double Wall Top.
If I wanted to get serious, I could drill 1/2'' holes periodically and shoot aerosol foam inside. But if it got carried away, that could irreversably bulge the interior space. And then you'd have to cap all those holes.
As is, there's a 1-3/4 to 2'' air gap between inside and outside.
Sound deadener and/or a layer of silver mylar-sided bubblewrap inside the doors and bed walls would be covered by the Door Panels and Vinyl Rear Panels. Maybe a rectangle of carpet could be glued on the inside Tailgate.
Old 07-25-2023, 08:44 PM   #4066
72c20customcamper
On the AMX
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-25-2023, 10:57 PM   #4067
'68OrangeSunshine
On the AMX
So the Distributor's in front, but the Carburetor's in the rear?
Old 07-25-2023, 11:11 PM   #4068
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Finally got around to installing my NOS Sport Mirrors. Link is for the install post.
http://67-72chevytrucks.com/vboard/s...d.php?t=846239
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-25-2023, 11:23 PM   #4069
coldrider
Havin fun...Don.
That's a lot of progress! Keep after it. (and post pics)
coldrider is offline   Reply With Quote
Old 07-26-2023, 07:48 AM   #4070
72c20customcamper
Yes AMC engines had a front distributor
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-26-2023, 05:01 PM   #4071
'68OrangeSunshine
Never had an AMC.
Old 07-30-2023, 09:32 AM   #4072
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Looks like I finally got my rear end leak fixed after using JB-Weld on a plug. What a PITA to have a leak on these plugs! Also changed out my starter and I think (hope) I am golden now.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 07-30-2023, 10:24 AM   #4073
RonWT
Active Member
RonWT's Avatar
I managed to put new rubber around both doors of the 69, I am going to attack some rubber replacements underneath next...
RonWT is offline   Reply With Quote
Old 07-30-2023, 02:58 PM   #4074
Jiggers72-GMC
Jiggers72-GMC's Avatar
I had to replace the battery then I took my truck for a spin around town, everyone loves it, feeling good
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 08-01-2023, 01:49 PM   #4075
3757chevy
3757chevy's Avatar
Originally Posted by 69Penka View Post
A few more pics...
Originally Posted by Rich72C10 View Post
Where you get that paint protector? I could use one of those.
Originally Posted by 3757chevy View Post
I was wondering the same thing.
Well after searching forever on my own for 2 weeks I found and ordered 2 from JLFabrication.com ...https://jlfabrication.com/collection...b6903769&_ss=r , hope this helps you Rich72C10.
I got them on UPS yesterday.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
