Anyone have a 454 with electric fans? Need advice
Just picked up a Flex-o-lite flx-295 electric fan kit for my Blazer. Got it on recommendation of a buddy who uses it on his 454 in his Chevelle. Well, I forgot to measure between the water pump and the radiator. Turns out I’m at 3.5” of clearance and the fan unit needs 4”.
Anyone dealt with this before? Gotta find a way to gain some space. Current thought is to somehow move the radiator forward. |
![]() Join Date: Mar 2003
Re: Anyone have a 454 with electric fans? Need advice
So you have a long water pump big block??
![]() Join Date: Dec 1999
If you moved motor forward to avoid driveline angles/problems. That may have created the space limitation. The single 19" PWM fan I used is pretty slim.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
| Bookmarks |
